[MPICH] Confused about compiling/using mpich2
    Gaetano Bellanca
    gaetano.bellanca at unife.it
    Sat Jan 12 16:44:02 CST 2008
Dear Rajeev
this is the (final part) of the output of make testing (I checked
this before and had similar errors of my simulation code).
Looking in ./threads/pt2pt/testlist
Unexpected output in threaded_sr: MPI_Init_thread must return
MPI_THREAD_MULTIPLE in order for this test to run.
Program threaded_sr exited without No Errors
Unexpected output in alltoall: [cli_0]: aborting job:
Unexpected output in alltoall: application called
MPI_Abort(MPI_COMM_WORLD, 1) - process 0
Unexpected output in alltoall: [cli_1]: aborting job:
MPI_Abort(MPI_COMM_WORLD, 1) - process 1
Unexpected output in alltoall: This test requires MPI_THREAD_MULTIPLE
Unexpected output in alltoall: [cli_2]: aborting job:
MPI_Abort(MPI_COMM_WORLD, 1) - process 2
Unexpected output in alltoall: rank 1 in job
1417  campi17_4545   caused collective abort of all ranks
Unexpected output in alltoall:   exit status of rank 1: return code 1
Unexpected output in alltoall: rank 0 in job
Unexpected output in alltoall:   exit status of rank 0: killed by signal 9
Program alltoall exited without No Errors
Unexpected output in sendselfth: MPI_Init_thread must return
Program sendselfth exited without No Errors
The options for configure are:
./configure --prefix=/opt/mpich2/1.0.6p1/intel10.1 --enable-cxx
--enable-f90 --enable-fast --enable-traceback --with-mpe
--enable-f90modules --enable-cache --enable-romio
--with-file-system=nfs+ufs+pvfs2 --with-device=ch3:nemesis
--with-pvfs2=/usr/local --with-java=/usr/lib/jvm/java-1.5.0-gcj-4.2-1.5.0.0
Before compiling I set : setenv F90 ifort
and load the environment for Intel compiler.
In this linux box (ubuntu server kernel 2.6.22-14)  I have a dual
Xeon, quad core processors. The MotherBoard has 2 network cards, but
only one is used at the moment.
Regards.
Gaetano
Gaetano Bellanca - Department of Engineering - University of Ferrara
Via Saragat, 1 - 44100 - Ferrara - ITALY
Voice (VoIP):  +39 0532 974809     Fax:  +39 0532 974870
mailto:gaetano.bellanca at unife.it
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080112/984e7fc5/attachment.htm>
