[MPICH] SMPD - Run smpd -d
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Thu Jan 10 10:20:06 CST 2008
 Please provide us the following,
1) The output of the configure script (configure.log)
    (I am assuming you did a "make /make install" after the configure
..."--with-pm=smpd". Just to make sure that you are not accessing a stale
version of smpd.)
2) The output after running smpd in debug mode (smpd -d)
Jayesh
  _____
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Krishna Chaitanya
Sent: Thursday, January 10, 2008 4:36 AM
Subject: [MPICH] SMPD
          I am trying to launch mpiexec on a single node and I ran the
configure script with the " --with-pm=smpd" and the smpd file was installed
in the bin subdir. However, when i try to launch the smp daemon, I get the
following :
./smpd -s
Please specify an authentication passphrase for this smpd:
Would you like to save this passphrase in '/home/kc/.smpd'? yes
[00:2915]..ERROR:MPIDU_Sock_listen failed,
sock error: generic socket failure, error stack:
MPIDU_Sock_listen(369): unable to bind socket to port
(port=135207912,errno=98:(strerror() not found))
           It would be of help if someone could let me know how to
troubleshoot this.
Krishna Chaitanya K
In the middle of difficulty, lies opportunity
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080110/cfe3ce8e/attachment.htm>
