[MPICH] Confused about compiling/using mpich2
    Darius Buntinas
    buntinas at mcs.anl.gov
    Mon Jan  7 09:49:08 CST 2008
The 'killed by signal 9' message means that the process manager killed
that process.  This typically happens when one of the other processes
died or exited without calling MPI_Finalize.  When this happens, the
process manager assumes that the process aborted and kills the rest of
the job.
So I would start by figuring out why the other process may be dying
(also make sure you're calling MPI_Finalize).
-d
On 01/05/2008 06:37 AM, Gaetano Bellanca wrote:
> Hi,
> I'm developing a parallel code using MPICH2 and I'm confused on how to
> choose the compiler options and how to use mpich2 on clusters of
> multicore processors.
> My code runs on a 32 bit, single core linux cluster  of 10PCs (pentium
> IV) without problems (with good performances on a pvfs2 filesystem), but
> does not run on an AMD 64 X2 Dual Core Processor 5600+ and on a Dual
> Processor Quad-core Intel Xeon linux box.
> In particular, the program stops during simple MPI_SEND and MPI_RECv
> operations when I run it with mpiexec -n 2 command with the message
> 'rank 1 in job 70 hostname_number caused collective abort of all ranks.
> exit status of rank 1: killed by signal 9'
> When I boot in Windows and run the same code using the Windows version
> of mpich2, it works regularly without problems.
> By reading the mpich2 guide, I see that there are different possible
> choices, for example, for the communication device, but I didn't see big
> differences by changing it: the code always stops with similar errors.
> Can someone please suggest me the better compiler options for mpich2
> compilation/use in Linux environment? I'm using the Intel Fortran 10.1
> compiler, and I'd like to use both the multicore and the multiprocessor
> facilities of the two different architectures (not mixing them, I mean
> using AMD and Intel separately).
> Thanks in advance.
> Gaetano
> Gaetano Bellanca - Department of Engineering - University of Ferrara
> Via Saragat, 1 - 44100 - Ferrara - ITALY
> Voice (VoIP):  +39 0532 974809     Fax:  +39 0532 974870
> mailto:gaetano.bellanca at unife.it
