[MPICH] build mpich2 with Myrinet GM
Wei-keng Liao
wkliao at ece.northwestern.edu
Wed Feb 27 22:18:33 CST 2008
OK. the patch fixed the problem and I was able to build the mpich. But
when I ran the test alltoallv in test/mpi/coll using 4 processes, it
failed with error message:
rank 2 in job 1 tg-c527_40397 caused collective abort
of all ranks
exit status of rank 2: killed by signal 9
The gdb on the coredump shows
(gdb) where
#0 0x20000000001c9120 in ?? ()
#1 0x40000000000a71d0 in send_pkt ()
#2 0x40000000000a6530 in MPID_nem_gm_iSendContig ()
#3 0x40000000000ab000 in MPIDI_CH3_iSendv ()
#4 0x400000000003e890 in MPIDI_CH3_EagerContigIsend ()
#5 0x4000000000048160 in MPID_Isend ()
#6 0x400000000000ec00 in MPIC_Isend ()
#7 0x400000000000a8e0 in MPIR_Alltoallv ()
#8 0x400000000000b2d0 in PMPI_Alltoallv ()
#9 0x4000000000003670 in main ()
#10 0x40000000000a71d0 in send_pkt ()
Wei-keng
On Wed, 27 Feb 2008, Darius Buntinas wrote:
> Sorry about that. I guess I didn't test this on an itanium after making
> some changes there.
> I've attached a patch file that should fix this. I'm still not sure why
> it's not working with your intel compiler.
> Apply the patch like this (from the mpich2 source directory)
> patch -p0 < ia64_atomics.patch
> Then do a make clean and make.
> -d
> On 02/27/2008 11:33 AM, Wei-keng Liao wrote:
> > I got a different error when I built mpich with gcc 3.2.2 at compiling file
> > nemesis/src/mpid_nem_alloc.c. (I used ifort for FC environment variable.)
> > In file included from ../include/mpid_nem_impl.h:13,
> > from mpid_nem_alloc.c:7:
> > ../include/mpid_nem_atomics.h: In function `MPID_NEM_SWAP':
> > ../include/mpid_nem_atomics.h:27: warning: dereferencing `void *' pointer
> > ../include/mpid_nem_atomics.h: In function `MPID_NEM_CAS':
> > ../include/mpid_nem_atomics.h:54: warning: dereferencing `void *' pointer
> > ../include/mpid_nem_atomics.h: In function `MPID_NEM_FETCH_AND_INC':
> > ../include/mpid_nem_atomics.h:164: parse error before string constant
> > Also, I tried Intel icc 8.1.037 and it failed with the message as icc
> > 9.0.032 and 9.1.046.
> > Wei-keng
> > On Tue, 26 Feb 2008, Darius Buntinas wrote:
> > > It looks like the icc compiler you're using doesn't like the gcc-style
> > > inline
> > > assembly code.
> > > What version of icc do you have?
> > > Can you try compiling with gcc instead of icc?
> > > -d
> > > On 02/26/2008 12:32 PM, Wei-keng Liao wrote:
> > > > Attached are 3 files:
> > > > out.configure - stdout from configure
> > > > out.make - stdout from make
> > > > config.log
> > > > Wei-keng
> > > > > Can you send us the output of configure as well as config.log?
> > > > > Thanks,
> > > > > -d
> > > > > On 02/26/2008 11:35 AM, Wei-keng Liao wrote:
> > > > > > I got an error during make:
> > > > > > ../include/mpid_nem_atomics.h(31): catastrophic error: #error
> > > > > > directive:
> > > > > > No
> > > > > > swap function defined for this architecture
> > > > > > #error No swap function defined for this architecture
> > > > > > compilation aborted for mpid_nem_alloc.c (code 4)
> > > > > > I am using configure options:
> > > > > > --with-device=ch3:nemesis:gm \
> > > > > > --with-gm=/opt/gm \
> > > > > > --enable-f77 --enable-f90 --enable-cxx \
> > > > > > --enable-fast \
> > > > > > --enable-romio \
> > > > > > --without-mpe \
> > > > > > --with-file-system=ufs
> > > > > > and the command "uname -a" on the machine is
> > > > > > Linux tg-login4 2.4.21-309.tg1 #1 SMP Thu Jun 1 17:07:28 CDT 2006
> > > > > > ia64
> > > > > > unknown
> > > > > > I am using Intel compiler v 9.1.043
> > > > > > Wei-keng
> > > > > > > On 02/26/2008 10:08 AM, Wei-keng Liao wrote:
> > > > > > > > I have a few questions on build mpich2-1.0.6p1 with Myrinet GM
> > > > > > > > library.
> > > > > > > > On my target machine, the GM library (include, lib, bin, etc.)
> > > > > > > > is in
> > > > > > > > /opt/gm. According to MPICH README, I used the 2 options below
> > > > > > > > when
> > > > > > > > configuring:
> > > > > > > > --with-device=ch3:nemesis:gm and --with-gm=/opt/gm
> > > > > > > > I can see both libgm.a and libgm.so are in /opt/gm/lib.
> > > > > > > > Q1: Do I need other configure options or setting environment
> > > > > > > > variables
> > > > > > > > (in addition to CC, FC, CXX, F90)? Should I set LDFLAGS to
> > > > > > > > "-L/opt/gm/lib -lgm" ?
> > > > > > > Nope, the --with-gm=/opt/gm should take care of all of that for
> > > > > > > you.
> > > > > > > > Q2: Since nemesis does not support MPI dynamic process routines
> > > > > > > > yet
> > > > > > > > and
> > > > > > > > I
> > > > > > > > need those routines, can I use --with-device=ch3:sock:gm
> > > > > > > > instead?
> > > > > > > No, only nemesis supports gm.
> > > > > > > > Q3: Do I need anything else (source codes, library) from Myrinet
> > > > > > > > to
> > > > > > > > build
> > > > > > > > mpich? Or the /opt/gm is good enough?
> > > > > > > All you need is libgm.a and gm.h.
> > > > > > > > Q4: Once the mpich is built, is there a way to verify that GM is
> > > > > > > > actually
> > > > > > > > used?
> > > > > > > Well, you should see a performance improvement over using sockets.
> > > > > > > Run a
> > > > > > > ping-pong test; you should see latencies around 10us or less.
> > > > > > > -d
