[MPICH] build mpich2 with Myrinet GM
Darius Buntinas buntinas at mcs.anl.gov
Wed Feb 27 15:32:29 CST 2008
Sorry about that.  I guess I didn't test this on an itanium after making
some changes there.
I've attached a patch file that should fix this.  I'm still not sure why
it's not working with your intel compiler.
Apply the patch like this (from the mpich2 source directory)
   patch -p0 < ia64_atomics.patch
Then do a make clean and make.
-d
On 02/27/2008 11:33 AM, Wei-keng Liao wrote:
> I got a different error when I built mpich with gcc 3.2.2 at compiling
> file nemesis/src/mpid_nem_alloc.c. (I used ifort for FC environment
> variable.)
> In file included from ../include/mpid_nem_impl.h:13,
>                  from mpid_nem_alloc.c:7:
> ../include/mpid_nem_atomics.h: In function `MPID_NEM_SWAP':
> ../include/mpid_nem_atomics.h:27: warning: dereferencing `void *' pointer
> ../include/mpid_nem_atomics.h: In function `MPID_NEM_CAS':
> ../include/mpid_nem_atomics.h:54: warning: dereferencing `void *' pointer
> ../include/mpid_nem_atomics.h: In function `MPID_NEM_FETCH_AND_INC':
> ../include/mpid_nem_atomics.h:164: parse error before string constant
> Also, I tried Intel icc 8.1.037 and it failed with the message as icc
> 9.0.032 and 9.1.046.
> Wei-keng
> On Tue, 26 Feb 2008, Darius Buntinas wrote:
>> It looks like the icc compiler you're using doesn't like the gcc-style inline
>> assembly code.
>> What version of icc do you have?
>> Can you try compiling with gcc instead of icc?
>> -d
>> On 02/26/2008 12:32 PM, Wei-keng Liao wrote:
>>> Attached are 3 files:
>>> out.configure  -  stdout from configure
>>> out.make       -  stdout from make
>>> config.log
>>> Wei-keng
>>>> Can you send us the output of configure as well as config.log?
>>>> Thanks,
>>>> -d
>>>> On 02/26/2008 11:35 AM, Wei-keng Liao wrote:
>>>>> I got an error during make:
>>>>> ../include/mpid_nem_atomics.h(31): catastrophic error: #error directive:
>>>>> No
>>>>> swap function defined for this architecture
>>>>>   #error No swap function defined for this architecture
>>>>> compilation aborted for mpid_nem_alloc.c (code 4)
>>>>> I am using configure options:
>>>>>           --with-device=ch3:nemesis:gm  \
>>>>>           --with-gm=/opt/gm \
>>>>>           --enable-f77 --enable-f90 --enable-cxx \
>>>>>           --enable-fast \
>>>>>           --enable-romio \
>>>>>           --without-mpe \
>>>>>           --with-file-system=ufs
>>>>> and the command "uname -a" on the machine is
>>>>> Linux tg-login4 2.4.21-309.tg1 #1 SMP Thu Jun 1 17:07:28 CDT 2006 ia64
>>>>> unknown
>>>>> I am using Intel compiler v 9.1.043
>>>>> Wei-keng
>>>>>> On 02/26/2008 10:08 AM, Wei-keng Liao wrote:
>>>>>>> I have a few questions on build mpich2-1.0.6p1 with Myrinet GM
>>>>>>> library.
>>>>>>> On my target machine, the GM library (include, lib, bin, etc.) is in
>>>>>>> /opt/gm. According to MPICH README, I used the 2 options below when
>>>>>>> configuring:
>>>>>>>     --with-device=ch3:nemesis:gm  and --with-gm=/opt/gm
>>>>>>> I can see both libgm.a and libgm.so are in /opt/gm/lib.
>>>>>>> Q1: Do I need other configure options or setting environment
>>>>>>> variables
>>>>>>>     (in addition to CC, FC, CXX, F90)? Should I set LDFLAGS to
>>>>>>>     "-L/opt/gm/lib -lgm" ?
>>>>>> Nope, the --with-gm=/opt/gm should take care of all of that for you.
>>>>>>> Q2: Since nemesis does not support MPI dynamic process routines yet
>>>>>>> and
>>>>>>> I
>>>>>>>     need those routines, can I use --with-device=ch3:sock:gm
>>>>>>>     instead?
>>>>>> No, only nemesis supports gm.
>>>>>>> Q3: Do I need anything else (source codes, library) from Myrinet to
>>>>>>> build
>>>>>>>     mpich? Or the /opt/gm is good enough?
>>>>>> All you need is libgm.a and gm.h.
>>>>>>> Q4: Once the mpich is built, is there a way to verify that GM is
>>>>>>> actually
>>>>>>>     used?
>>>>>> Well, you should see a performance improvement over using sockets.
>>>>>> Run a
>>>>>> ping-pong test; you should see latencies around 10us or less.
>>>>>> -d
Type: text/x-patch
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080227/4ac96c6c/attachment.bin>
