[MPICH] Loopback Communication
Anthony Chan
chan at mcs.anl.gov
Wed Feb 27 17:08:43 CST 2008
Did you configure mpich2 --with-device=ch3:nemesis which uses shared
memory for intranode communication ?
A.Chan
On Wed, 27 Feb 2008, Elvedin Trnjanin wrote:
> I have a "ping pong" latency and bandwidth measurement program that I'm
> using for approximating performance of an Infiniband cluster. I've
> noticed that for self to self asynchronous communication with
> mpirun_ssh, to transfer a 1MB message, it takes around 3.2 ms while with
> node A to node B communication, the latency is around 2.9 ms per 1MB
> message. On the bandwidth side, self to self communication is 60MB/s
> slower. Although 60MB/s difference might not seem like a significant
> problem considering the total bandwidth for the larger message
> Infiniband transfers, on a small Gigabit Ethernet cluster I use, our
> node to node asynchronous communication bandwidth is slightly less than
> 60MB/s. That difference is pretty significant to me.
> My question is if anyone can explain why self to self communication is
> slower and also why the interconnect is involved instead of doing a
> memory copy? I apologize ahead of time if this issue has been discussed
> in the MPI2 standards but I'm reading the (unofficial) report and
> haven't found it yet.
> Regards,
> Elvedin Trnjanin
