[MPICH] Compiling a program (john-mpi MPICH2) under cygwin / WinXP - specify libs after source file
    madfran
    madfran at set-ezine.org
    Thu Feb 21 17:05:53 CST 2008
I begin to think it is imposible :-(
gcc DES_bs_b.c -c -Wall -O3 -fomit-frame-pointer -
I/cygdrive/c/Progra~1/MPICH2/include -L/cygdrive/c/Progra~1/MPICH2/lib -
lmpicxx -lfmpich2 -lmpi -finline-functions
gcc: -lmpicxx: linker input file unused because linking not done
gcc: -lfmpich2: linker input file unused because linking not done
gcc: -lmpi: linker input file unused because linking not done
gcc x86.o x86-mmx.o  md4-sse2.o NTmmx_fmt.o md5-mmx.o sha1-mmx.o DES_fmt.o
DES_std.o DES_bs.o BSDI_fmt.o MD5_fmt.o MD5_std.o BF_fmt.o BF_std.o AFS_fmt.o
LM_fmt.o des.o MD5_apache_fmt.o BFEgg_fmt.o lotus5_fmt.o md5.o NSLDAP_fmt.o
NSLDAPS_fmt.o sha1.o base64.o MYSQL_fmt.o NT_fmt.o md4.o smbencrypt.o
rawMD5_fmt.o rawSHA1_
fmt.o mssql_fmt.o hmacMD5_fmt.o WPAPSK_fmt.o mscash_fmt.o oracle_fmt.o
batch.o bench.o charset.o common.o compiler.o config.o cracker.o crc32.o
external.o formats.o getopt.o idle.o inc.o john.o list.o loader.o logger.o
math.o memory.o misc.o options.o params.o path.o recovery.o rpp.o rules.o
signals.o single.o status.o tty.o wordlist.o unshadow.o ryan.o unafs.o
undrop.o unique.o DES_bs_b.o -lkernel32 -o ../run/john.exe
hmacMD5_fmt.o:hmacMD5_fmt.c:(.text+0x6c3): undefined reference to
`_mdfivemmx_no sizeupdate'
hmacMD5_fmt.o:hmacMD5_fmt.c:(.text+0x6db): undefined reference to
`_mdfivemmx_no
init_uniformsizeupdate'
hmacMD5_fmt.o:hmacMD5_fmt.c:(.text+0x6ef): undefined reference to
`_mdfivemmx_no
sizeupdate'
hmacMD5_fmt.o:hmacMD5_fmt.c:(.text+0x703): undefined reference to
`_mdfivemmx_no
bench.o:bench.c:(.text+0x849): undefined reference to `_MPI_Reduce'
bench.o:bench.c:(.text+0x91f): undefined reference to `_MPI_Reduce'
bench.o:bench.c:(.text+0x9f2): undefined reference to `_MPI_Reduce'
bench.o:bench.c:(.text+0xab0): undefined reference to `_MPI_Reduce'
john.o:john.c:(.text+0x33): undefined reference to `_MPI_Init'
john.o:john.c:(.text+0x43): undefined reference to `_MPI_Comm_rank'
john.o:john.c:(.text+0x53): undefined reference to `_MPI_Comm_size'
john.o:john.c:(.text+0x6e3): undefined reference to `_MPI_Finalize'
john.o:john.c:(.text+0x721): undefined reference to `_MPI_Finalize'
john.o:john.c:(.text+0x741): undefined reference to `_MPI_Finalize'
john.o:john.c:(.text+0x8f1): undefined reference to `_MPI_Finalize'
john.o:john.c:(.text+0xa92): undefined reference to `_MPI_Finalize'
misc.o:misc.c:(.text+0x38): more undefined references to `_MPI_Finalize'
follow
collect2: ld returned 1 exit status
make[1]: *** [../run/john.exe] Error 1
make[1]: Leaving directory `/tmp/john-mpi/john-1.7.2-bp17-mpi6/src'
make: *** [win32-cygwin-x86-sse2] Error 2
On Thu, 21 Feb 2008 12:51:30 -0600, Jayesh Krishna wrote
> Hi,
>  Please specify the libraries after the source file.
> gcc -Wall -O3 -fomit-frame-pointer -I/cygdrive/c/Progra~1/MPICH2/include
> -L/cygdrive/c/Progra~1/MPICH2/lib -funroll-loops NTmmx_fmt.c -lmpicxx
> -lfmpich2 -lmpi
> Regards,
> Jayesh
> -----Original Message-----
> From: madfran [mailto:madfran at set-ezine.org]
> Sent: Thursday, February 21, 2008 12:02 PM
> To: Jayesh Krishna
> Cc: mpich-discuss at mcs.anl.gov
> Subject: RE: [MPICH] Compiling a program (john-mpi MPICH2) under
> cygwin / WinXP - use -lmpicxx
> Hi,...
> Not luck :-(
> gcc -c -Wall -O3 -fomit-frame-pointer -I/cygdrive/c/Progra~1/MPICH2/include
> - L/cygdrive/c/Progra~1/MPICH2/lib -lmpicxx -lfmpich2 -lmpi -funroll-
> loops NTmmx_fmt.c NTmmx_fmt.c:63: warning: alignment of
> 'saved_plain' is greater than maximum object file alignment.  Using
> 16 NTmmx_fmt.c:65: warning: alignment of 'output' is greater than maximum
> object file alignment.  Using 16
> gcc: -lmpi: linker input file unused because linking not done gcc -c
> -DUNDERSCORES md5-mmx.S gcc -c  -DUNDERSCORES sha1-mmx.S gcc
> DES_fmt.o DES_std.o DES_bs.o BSDI_fmt.o MD5_fmt.o MD5_std.o BF_fmt.o
> BF_std. o AFS_fmt.o LM_fmt.o des.o MD5_apache_fmt.o BFEgg_fmt.o
> lotus5_fmt.o md5.o NSLDA P_fmt.o NSLDAPS_fmt.o sha1.o base64.o
> MYSQL_fmt.o NT_fmt.o md4.o smbencrypt.o ra wMD5_fmt.o rawSHA1_fmt.o
> mssql_fmt.o hmacMD5_fmt.o WPAPSK_fmt.o mscash_fmt.o ora cle_fmt.o
> crc32 .o external.o formats.o getopt.o idle.o inc.o john.o list.o loader.o
> logger.o ma th.o memory.o misc.o options.o params.o path.o
> recovery.o rpp.o rules.o signals. o single.o status.o tty.o
> wordlist.o unshadow.o ryan.o unafs.o undrop.o unique.o  DES_bs_b.o
> x86.o x86-mmx.o  md4-sse2.o NTmmx_fmt.o md5-mmx.o sha1-mmx.o -
> lkerne l32 -o ../run/john.exe
> `_mdfivemmx_no sizeupdate' hmacMD5_fmt.o:hmacMD5_fmt.c:(.text+0x6db)
> : undefined reference to `_mdfivemmx_no init_uniformsizeupdate'
> `_mdfivemmx_no sizeupdate' hmacMD5_fmt.o:hmacMD5_fmt.c:(.text+0x703)
> `_MPI_Finalize' follow collect2: ld returned 1 exit status make[1]:
> *** [../run/john.exe] Error 1 make[1]: Leaving directory `/tmp/john-
> mpi/john-1.7.2-bp17-mpi6/src' make: *** [win32-cygwin-x86-sse2]
> Error 2
> On Wed, 20 Feb 2008 15:24:18 -0600, Jayesh Krishna wrote
> > Hi,
> >  Try,
> > gcc -c ... -lmpicxx -lfmpich2 -lmpi ...
> > (Note: I used "-lmpicxx" instead of "-llibmpicxx" )
> > Regards,
> > Jayesh
> > Sent: Wednesday, February 20, 2008 3:16 PM
> > To: Jayesh Krishna
> > cygwin / WinXP - use libmpicxx.a
> > Hi,...
> > The problem is not solved.
> > - L/cygdrive/c/Progra~1/MPICH2/lib -llibmpicxx -lmpi -lfmpich2
> > -funroll-loops NTmmx _fmt.c
> > NTmmx_fmt.c:63: warning: alignment of 'saved_plain' is greater than
> > maximum object file alignment.  Using 16
> > object file alignment.  Using 16 gcc: -llibmpicxx: linker input file
> > unused because linking not done gcc: -lmpi: linker input file unused
> > because linking not done gcc: -lfmpich2: linker input file unused
> > because linking not done ...........
> `_MPI_Reduce' ...........
> > On Tue, 19 Feb 2008 16:39:52 -0600, Jayesh Krishna wrote
> > > Hi,
> > >   If you want to compile MPI programs written in C++ from cygwin use
> > > the libmpicxx.a library (not cxx.lib) in MPICH2\lib.
> > > Regards,
> > > Jayesh
> > > From: owner-mpich-discuss at mcs.anl.gov
> > > [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of madfran
> > > Sent: Tuesday, February 19, 2008 4:09 PM
> > > To: mpich-discuss at mcs.anl.gov
> > > Subject: [MPICH] Compiling a program (john-mpi MPICH2) under cygwin
> > > / WinXP
> > > Hi,...
> > > Trying to build a program under cygwin / WinXP I had received these
> > > messages.
> > > MPICH2 is installed only under WinXP.
> > > Any idea?
> > > - L/c
> > > ygdrive/c/Progra~1/MPICH2/lib -lcxx.lib -lmpi -lfmpich2 -funroll-
> > > loops   NTmmx_f mt.c NTmmx_fmt.c:63: warning: alignment of
> > > 'saved_plain' is greater than maximum obje ct file alignment.  Using
> > > maximum object fi le alignment.  Using 16
> > > gcc: -lcxx.lib: linker input file unused because linking not done
> > > gcc -c -DUNDERSCORES md5-mmx.S gcc -c  -DUNDERSCORES sha1-mmx.S gcc
> > DES_fmt.o
> > > o AFS_fmt.o LM_fmt.o des.o MD5_apache_fmt.o BFEgg_fmt.o lotus5_fmt.o
> > > md5.o NSLDA P_fmt.o NSLDAPS_fmt.o sha1.o base64.o MYSQL_fmt.o
> > > NT_fmt.o md4.o smbencrypt.o ra wMD5_fmt.o rawSHA1_fmt.o mssql_fmt.o
> > hmacMD5_fmt.o
> > > WPAPSK_fmt.o mscash_fmt.o ora cle_fmt.o batch.o bench.o charset.o
> > > crc32
> > > x86.o x86-mmx.o md4-sse2.o NTmmx_fmt.o md5-mmx.o sha1-mmx.o - lkerne
> > > Error
> > > 2
