[MPICH] Compiling a program (john-mpi MPICH2) under cygwin / WinXP - specify libs after source file
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Thu Feb 21 12:51:30 CST 2008
 Please specify the libraries after the source file.
gcc -Wall -O3 -fomit-frame-pointer -I/cygdrive/c/Progra~1/MPICH2/include
-L/cygdrive/c/Progra~1/MPICH2/lib -funroll-loops NTmmx_fmt.c -lmpicxx
-lfmpich2 -lmpi
Jayesh
-----Original Message-----
Sent: Thursday, February 21, 2008 12:02 PM
To: Jayesh Krishna
Cc: mpich-discuss at mcs.anl.gov
Subject: RE: [MPICH] Compiling a program (john-mpi MPICH2) under cygwin /
WinXP - use -lmpicxx
Hi,...
Not luck :-(
gcc -c -Wall -O3 -fomit-frame-pointer -I/cygdrive/c/Progra~1/MPICH2/include
- L/cygdrive/c/Progra~1/MPICH2/lib -lmpicxx -lfmpich2 -lmpi -funroll-loops
NTmmx_fmt.c
NTmmx_fmt.c:63: warning: alignment of 'saved_plain' is greater than maximum
object file alignment.  Using 16
NTmmx_fmt.c:65: warning: alignment of 'output' is greater than maximum
gcc: -lmpicxx: linker input file unused because linking not done
gcc: -lfmpich2: linker input file unused because linking not done
gcc: -lmpi: linker input file unused because linking not done gcc -c
-DUNDERSCORES md5-mmx.S gcc -c  -DUNDERSCORES sha1-mmx.S gcc DES_fmt.o
DES_std.o DES_bs.o BSDI_fmt.o MD5_fmt.o MD5_std.o BF_fmt.o BF_std.
o AFS_fmt.o LM_fmt.o des.o MD5_apache_fmt.o BFEgg_fmt.o lotus5_fmt.o md5.o
NSLDA P_fmt.o NSLDAPS_fmt.o sha1.o base64.o MYSQL_fmt.o NT_fmt.o md4.o
smbencrypt.o ra wMD5_fmt.o rawSHA1_fmt.o mssql_fmt.o hmacMD5_fmt.o
WPAPSK_fmt.o mscash_fmt.o ora cle_fmt.o batch.o bench.o charset.o common.o
compiler.o config.o cracker.o
crc32
.o external.o formats.o getopt.o idle.o inc.o john.o list.o loader.o
logger.o ma th.o memory.o misc.o options.o params.o path.o recovery.o rpp.o
rules.o signals.
o single.o status.o tty.o wordlist.o unshadow.o ryan.o unafs.o undrop.o
unique.o  DES_bs_b.o x86.o x86-mmx.o  md4-sse2.o NTmmx_fmt.o md5-mmx.o
sha1-mmx.o - lkerne
l32 -o ../run/john.exe
hmacMD5_fmt.o:hmacMD5_fmt.c:(.text+0x6c3): undefined reference to
`_mdfivemmx_no sizeupdate'
hmacMD5_fmt.o:hmacMD5_fmt.c:(.text+0x6db): undefined reference to
`_mdfivemmx_no init_uniformsizeupdate'
hmacMD5_fmt.o:hmacMD5_fmt.c:(.text+0x6ef): undefined reference to
hmacMD5_fmt.o:hmacMD5_fmt.c:(.text+0x703): undefined reference to
bench.o:bench.c:(.text+0x849): undefined reference to `_MPI_Reduce'
bench.o:bench.c:(.text+0x91f): undefined reference to `_MPI_Reduce'
bench.o:bench.c:(.text+0x9f2): undefined reference to `_MPI_Reduce'
bench.o:bench.c:(.text+0xab0): undefined reference to `_MPI_Reduce'
john.o:john.c:(.text+0x33): undefined reference to `_MPI_Init'
john.o:john.c:(.text+0x43): undefined reference to `_MPI_Comm_rank'
john.o:john.c:(.text+0x53): undefined reference to `_MPI_Comm_size'
john.o:john.c:(.text+0x6e3): undefined reference to `_MPI_Finalize'
john.o:john.c:(.text+0x721): undefined reference to `_MPI_Finalize'
john.o:john.c:(.text+0x741): undefined reference to `_MPI_Finalize'
john.o:john.c:(.text+0x8f1): undefined reference to `_MPI_Finalize'
john.o:john.c:(.text+0xa92): undefined reference to `_MPI_Finalize'
misc.o:misc.c:(.text+0x38): more undefined references to `_MPI_Finalize'
follow
collect2: ld returned 1 exit status
make[1]: *** [../run/john.exe] Error 1
make[1]: Leaving directory `/tmp/john-mpi/john-1.7.2-bp17-mpi6/src'
make: *** [win32-cygwin-x86-sse2] Error 2
On Wed, 20 Feb 2008 15:24:18 -0600, Jayesh Krishna wrote
> Hi,
>  Try,
> gcc -c ... -lmpicxx -lfmpich2 -lmpi ...
> (Note: I used "-lmpicxx" instead of "-llibmpicxx" )
> Regards,
> Jayesh
> From: madfran [mailto:madfran at set-ezine.org]
> Sent: Wednesday, February 20, 2008 3:16 PM
> To: Jayesh Krishna
> cygwin / WinXP - use libmpicxx.a
> Hi,...
> The problem is not solved.
> - L/cygdrive/c/Progra~1/MPICH2/lib -llibmpicxx -lmpi -lfmpich2
> -funroll-loops NTmmx _fmt.c
> maximum object file alignment.  Using 16
> object file alignment.  Using 16 gcc: -llibmpicxx: linker input file
> unused because linking not done gcc: -lmpi: linker input file unused
> because linking not done gcc: -lfmpich2: linker input file unused
> because linking not done ...........
`_MPI_Reduce' ...........
> On Tue, 19 Feb 2008 16:39:52 -0600, Jayesh Krishna wrote
> > Hi,
> >   If you want to compile MPI programs written in C++ from cygwin use
> > the libmpicxx.a library (not cxx.lib) in MPICH2\lib.
> > Regards,
> > Jayesh
> > From: owner-mpich-discuss at mcs.anl.gov
> > [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of madfran
> > Sent: Tuesday, February 19, 2008 4:09 PM
> > To: mpich-discuss at mcs.anl.gov
> > Subject: [MPICH] Compiling a program (john-mpi MPICH2) under cygwin
> > / WinXP
> > Hi,...
> > Trying to build a program under cygwin / WinXP I had received these
> > messages.
> > MPICH2 is installed only under WinXP.
> > Any idea?
> > - L/c
> > ygdrive/c/Progra~1/MPICH2/lib -lcxx.lib -lmpi -lfmpich2 -funroll-
> > loops   NTmmx_f mt.c NTmmx_fmt.c:63: warning: alignment of
> > 'saved_plain' is greater than maximum obje ct file alignment.  Using
> > 16 NTmmx_fmt.c:65: warning: alignment of 'output' is greater than
> > maximum object fi le alignment.  Using 16
> > gcc: -lcxx.lib: linker input file unused because linking not done
> > gcc -c -DUNDERSCORES md5-mmx.S gcc -c  -DUNDERSCORES sha1-mmx.S gcc
> DES_fmt.o
> > md5.o NSLDA P_fmt.o NSLDAPS_fmt.o sha1.o base64.o MYSQL_fmt.o
> > NT_fmt.o md4.o smbencrypt.o ra wMD5_fmt.o rawSHA1_fmt.o mssql_fmt.o
> hmacMD5_fmt.o
> > common.o compiler.o config.o cracker.o
> > crc32
> > recovery.o rpp.o rules.o signals. o single.o status.o tty.o
> > wordlist.o unshadow.o ryan.o unafs.o undrop.o unique.o  DES_bs_b.o
> > x86.o x86-mmx.o md4-sse2.o NTmmx_fmt.o md5-mmx.o sha1-mmx.o - lkerne
> > `_mdfivemmx_no sizeupdate' hmacMD5_fmt.o:hmacMD5_fmt.c:(.text+0x6db)
> > : undefined reference to `_mdfivemmx_no init_uniformsizeupdate'
> > `_mdfivemmx_no sizeupdate' hmacMD5_fmt.o:hmacMD5_fmt.c:(.text+0x703)
> > `_MPI_Finalize' follow collect2: ld returned 1 exit status make[1]:
> > *** [../run/john.exe] Error 1 make[1]: Leaving directory `/tmp/john-
> > mpi/john-1.7.2-bp17-mpi6/src' make: *** [win32-cygwin-x86-sse2]
> > Error
> > 2
