[MPICH] Problems with mpd
    Gaetano Bellanca
    gaetano.bellanca at unife.it
    Thu Feb 14 17:25:24 CST 2008
I'm trying to set-up mpich2 (last version) on a linux cluster (ubuntu
gutsy) and I'm having some problems using root mpd from a normal
user. I'm following the tests indicated in the manual, and everything
is fine using mpd as a normal user.
Running mpd at boot from root, when I'm on the server machine, a
normal user is able to run mpiexec -n 1 hostname getting the correct
hostname answer.
On the slave machine, on the contrary, it results with the following message:
/opt/mpich2/1.0.6p1/intel10.1/bin/mpdroot: open failed for root's mpd
conf filempiexec_cluster3 (__init__ 1190): forked process failed; status=255
It seems to be a problem relevant to the /etc/mpd.conf file. But this
file is the same I have on the server (with same permissions).
The command is executed regularly on the slave machine with sudo
mpiexec -n 1 hostname.
Could it be a problem relevant to the fact that, the mpich2 directory
is mounted from the server via nfs?
Regards.
Gaetano
Gaetano Bellanca - Department of Engineering - University of Ferrara
Via Saragat, 1 - 44100 - Ferrara - ITALY
Voice (VoIP):  +39 0532 974809     Fax:  +39 0532 974870
mailto:gaetano.bellanca at unife.it
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080215/5e6a07d6/attachment.htm>
