[MPICH] Problem setting up MPICH between a 32 bit INTEL and a 32 bit AMD machine
    Dave Goodell
    goodell at mcs.anl.gov
    Thu Feb 14 13:15:55 CST 2008
Something is likely incorrect in your DNS resolution or /etc/hosts
file.  Please re-run the "mpdcheck -f mpd.hosts" check with the "-v"
option and send us the output.  This should help to see which hosts
in particular are causing a problem and/or if we are getting bitten
by some sort of aliasing.
-Dave
On Feb 14, 2008, at 10:26 AM, Krishna Chaitanya wrote:
> Hi,
>         In one of the previous posts, you had replied back saying
> MPICH cannot be put to use between a 32 bit INTEL machine and a 64
> bit AMD machine. Is it possible to do so between an INTEL and an
> AMD machine, both of them being 32 bit processors?
>         Anyway, on trying mpdcheck -f mpd.hosts on the 32 bit AMD,
> I am getting the following error :
>    ipaddr via uqn (208.67.216.130) does not match via fqn
> (208.69.32.130)
>         And if I try the mpdcheck -s on the AMD node and mpdcheck -
> c on the INTEL node, the client times out. The test message gets
> delivered with the client and server swapped.
> Thanks,
> Krishna Chaitanya K
> In the middle of difficulty, lies opportunity
