[MPICH] two quick questions about MPICH2 on windows
Jayesh Krishna jayesh at mcs.anl.gov
Tue Feb 12 14:10:18 CST 2008
>> a) We want to increase the number of windows machines to run our MPICH2
application and some of the new machines are in a different country. Do all
windows machines have to be
>> in the same windows domain in order to run the MPI App?
        You don't need all the windows machines to be in the same domain to
run your MPI application. However you must make sure that all the machines
have a local user with the same username+password . You can register, say
user 2, using mpiexec (mpiexec -register -user 2) and use that user to run
your MPI app (mpiexec -user 2 -n 10 myapp.exe).
>> b) Is there a tool to monitor our MPI APP and check the status of all the
machines without login to each one of them? Something we can run from a
single machine.
        There is no tool currently to monitor the status of MPI apps
(Although we have plans for the same). You can check the status of the
process manager, smpd, from any machine by specifying the hostname as part
of the "-status" option of smpd (smpd -status hostname). This command will
let you know if PM/smpd is running on the host.
  Let us know if you need further information.
Jayesh
  _____
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Richard Li
Sent: Monday, February 11, 2008 5:36 PM
Subject: [MPICH] two quick questions about MPICH2 on windows
I have two quick questions regarding MPICH2 windows version:
single machine.
Thanks
Richard
  _____
Need to know the score, the latest news, or you need your HotmailR-get your
"fix". Check it  <http://www.msnmobilefix.com/Default.aspx> out.
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080212/8904d952/attachment.htm>
