FW: [MPICH] mpich2: smpd phrase missing? - set SMPD_OPTION_NO_DYNAMIC_HOSTS
Jayesh Krishna
jayesh at mcs.anl.gov
Mon Feb 11 11:59:42 CST 2008
> -----Original Message-----
> From: Jayesh Krishna [mailto:jayesh at mcs.anl.gov]
> Sent: Friday, February 08, 2008 3:59 PM
> To: 'Stefan Becuwe'
> Subject: RE: [MPICH] mpich2: smpd phrase missing? - set
> Hi,
> I have fixed some bugs in the code. Now, with the upcoming
> latest release (1.0.7 - available in couple of weeks - or you
> could extract the latest source from svn) you should be able
> to set the environment variable,
> SMPD_OPTION_NO_DYNAMIC_HOSTS, to 1 and inform smpd daemons
> not to update (add dynamic hosts) the smpd config file. Since
> multiple smpd daemons don't update the config file (with the
> prev env var set) you don't need different conf files for the
> daemons (all daemons can share the .smpd config file in your
> shared home directory)
> So this is what you would have to do,
> 1) Set the environment variable SMPD_OPTION_NO_DYNAMIC_HOSTS
> to 1 (In all the nodes).
> 2) Create .smpd file in your HOME directory (possibly shared
> across nodes) with the passphrase (The only line in the smpd
> config file should be the passphrase, phrase=myphrase. Delete
> any other lines in the config file)
> 3) Start smpd, smpd -s, in each node (Note that you no longer
> need to specify the smpd config file as an option here) .
> 4) Run mpiexec, mpiexec -n 2 -machinefile mf.txt cpi (Note
> that you no longer need to specify the smpd config file as an
> option here) .
> Regards,
> Jayesh
> From: Stefan Becuwe [mailto:stefan.becuwe at ua.ac.be]
> Sent: Monday, January 21, 2008 5:30 PM
> To: Jayesh Krishna
> Subject: RE: [MPICH] mpich2: smpd phrase missing? - did you
> specify -smpdfile for smpd&mpixec ?
> > Have you specified the "-smpdfile a_copy_of_my_smpd_file"
> option for
> > smpd & mpiexec ? The MPICH2 user's guide
> (http://www.mcs.anl.gov/research/projects/mpich2/documentation/index.p
> > hp?s=d
> > ocs) contains information about the different options
> available with
> > mpiexec/smpd.
> Isn't there a possibility that a user defines his own
> smpdfile (or none), without having to change the "system"
> defaults for smpd? FYI: I'm using GridEngine (and Reuthi's
> tight integration scripts). As far as I understand, this
> would imply again 1 specific smpdfile for all daemons...
> which leads to locking problems. Or is there a simpler setup
> (for GridEngine)?
> Regards
> Stefan
