[MPICH] Problem with MPI_TYPE_CREATE_RESIZED
Pavan Balaji
balaji at mcs.anl.gov
Mon Feb 11 02:42:10 CST 2008
Can you try the attached patch and see if the problem still exists? The
patch is against mpich2-1.0.6p1:
$ cd mpich2-1.0.6p1 && patch -p0 < dataloop.patch
Thanks.
-- Pavan
On 02/10/2008 11:28 AM, Rajeev Thakur wrote:
> I can reproduce the problem with Intel 9.1 compilers but not with gcc (3.4).
> We will look into it.
> Rajeev
>> -----Original Message-----
>> From: Trach-Minh Tran [mailto:trach-minh.tran at epfl.ch]
>> Sent: Sunday, February 10, 2008 11:10 AM
>> To: Rajeev Thakur
>> Cc: 'MPICH Discuss'
>> Subject: Re: [MPICH] Problem with MPI_TYPE_CREATE_RESIZED
>> I have rebuild mpich2-1.0.6 with gfortran/gcc/g++ (GCC-4.1.2)
>> and ... the error is gone! However with the C version of my
>> example, the same error reappears!
>> #include "mpi.h"
>> #include <stdio.h>
>> MPI_Datatype LINE_TYPE, LINES_TYPE;
>> MPI_Aint lb, extent;
>> int main(int argc,char *argv[])
>> MPI_Init(&argc,&argv);
>> MPI_Type_vector(10, 1, 10, MPI_INT, &LINE_TYPE);
>> MPI_Type_commit(&LINE_TYPE);
>> MPI_Type_get_extent(LINE_TYPE, &lb, &extent);
>> printf("LINE_TYPE: lb = %d, extent = %d\n", lb, extent);
>> MPI_Type_get_extent(MPI_INT, &lb, &extent);
>> MPI_Type_create_resized(LINE_TYPE, lb, extent, &LINES_TYPE);
>> MPI_Type_commit(&LINES_TYPE);
>> MPI_Type_get_extent(LINES_TYPE, &lb, &extent);
>> printf("LINES_TYPE: lb = %d, extent = %d\n", lb, extent);
>> MPI_Finalize();
>> return 0;
>> $ mpiexec -n 1 ./a.out
>> LINE_TYPE: lb = 0, extent = 364
>> Assertion failed in file dataloop.c at line 554: old_loop_sz > 0
>> [cli_0]: aborting job:
>> internal ABORT - process 0
>> rank 0 in job 5 gimel3_45420 caused collective abort of all ranks
>> exit status of rank 0: return code 1
>> Best regards, -Minh.
>> On 02/10/2008 03:28 PM, Rajeev Thakur wrote:
>>> I can't reproduce the error. What compiler are you using?
>> Also, it may
>>> not matter but it should be integer(kind=MPI_ADDRESS_KIND).
>>> Rajeev
>>>> From: owner-mpich-discuss at mcs.anl.gov
>>>> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of
>> Trach-Minh Tran
>>>> Sent: Sunday, February 10, 2008 2:16 AM
>>>> To: MPICH Discuss
>>>> Subject: [MPICH] Problem with MPI_TYPE_CREATE_RESIZED
>>>> Hello,
>>>> Using mpich2-1.0.6p1, MPI_TYPE_CREATE_RESIZED produces an error.
>>>> Running the following fortran program aborts with the error:
>>>> With versions prior to 1.0.5, this programs runs without any error.
>>>> Regards, -Minh.
>>>> PROGRAM main
>>>> USE mpi
>>>> IMPLICIT NONE
>>>> INTEGER :: ierr, LINE_TYPE, LINES_TYPE
>>>> INTEGER(MPI_ADDRESS_KIND) :: extent, lb !
>>>> CALL MPI_INIT(ierr)
>>>> CALL MPI_TYPE_VECTOR(10, 1, 10, MPI_INTEGER, LINE_TYPE, ierr)
>>>> CALL MPI_TYPE_COMMIT(LINE_TYPE, ierr) !
>>>> CALL MPI_TYPE_GET_EXTENT(MPI_INTEGER, lb, extent, ierr)
>>>> CALL MPI_TYPE_CREATE_RESIZED(LINE_TYPE, lb, extent, LINES_TYPE,
>>>> ierr)
>>>> CALL MPI_TYPE_COMMIT(LINES_TYPE, ierr) !
>>>> CALL MPI_TYPE_GET_EXTENT(LINES_TYPE, lb, extent, ierr)
>>>> PRINT*, 'LINES_TYPE: lb, extent', lb, extent !
>>>> CALL MPI_FINALIZE(ierr)
>>>> END PROGRAM main
>> Dr. Trach-Minh Tran
>> CRPP/SB/EPFL http://crppwww.epfl.ch
>> Swiss Federal Institute of Technology
>> CH-1015 Lausanne
>> Office: http://plan.epfl.ch/?room=PPB111
>> Tel: +41 21 693 4569
>> Fax: +41 21 693 5176
Pavan Balaji
http://www.mcs.anl.gov/~balaji
Type: text/x-patch
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080211/fa715706/attachment.bin>
