[MPICH] Problem with MPI_TYPE_CREATE_RESIZED
    Rajeev Thakur
    thakur at mcs.anl.gov
    Sun Feb 10 11:28:46 CST 2008
I can reproduce the problem with Intel 9.1 compilers but not with gcc (3.4).
We will look into it.
Rajeev
> -----Original Message-----
> From: Trach-Minh Tran [mailto:trach-minh.tran at epfl.ch]
> Sent: Sunday, February 10, 2008 11:10 AM
> To: Rajeev Thakur
> Cc: 'MPICH Discuss'
> Subject: Re: [MPICH] Problem with MPI_TYPE_CREATE_RESIZED
> I have rebuild mpich2-1.0.6 with gfortran/gcc/g++ (GCC-4.1.2)
> and ... the error is gone! However with the C version of my
> example, the same error reappears!
> #include "mpi.h"
> #include <stdio.h>
> MPI_Datatype LINE_TYPE,  LINES_TYPE;
> MPI_Aint lb, extent;
> int main(int argc,char *argv[])
>   MPI_Init(&argc,&argv);
>   MPI_Type_vector(10, 1, 10, MPI_INT, &LINE_TYPE);
>   MPI_Type_commit(&LINE_TYPE);
>   MPI_Type_get_extent(LINE_TYPE, &lb, &extent);
>   printf("LINE_TYPE: lb = %d, extent = %d\n", lb, extent);
>   MPI_Type_get_extent(MPI_INT, &lb, &extent);
>   MPI_Type_create_resized(LINE_TYPE, lb, extent, &LINES_TYPE);
>   MPI_Type_commit(&LINES_TYPE);
>   MPI_Type_get_extent(LINES_TYPE, &lb, &extent);
>   printf("LINES_TYPE: lb = %d, extent = %d\n", lb, extent);
>   MPI_Finalize();
>   return 0;
> $ mpiexec -n 1 ./a.out
> LINE_TYPE: lb = 0, extent = 364
> Assertion failed in file dataloop.c at line 554: old_loop_sz > 0
> [cli_0]: aborting job:
> internal ABORT - process 0
> rank 0 in job 5  gimel3_45420   caused collective abort of all ranks
>   exit status of rank 0: return code 1
> Best regards,   -Minh.
> On 02/10/2008 03:28 PM, Rajeev Thakur wrote:
> > I can't reproduce the error. What compiler are you using?
> Also, it may
> > not matter but it should be integer(kind=MPI_ADDRESS_KIND).
> > Rajeev
> >> From: owner-mpich-discuss at mcs.anl.gov
> >> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of
> Trach-Minh Tran
> >> Sent: Sunday, February 10, 2008 2:16 AM
> >> To: MPICH Discuss
> >> Subject: [MPICH] Problem with MPI_TYPE_CREATE_RESIZED
> >> Hello,
> >> Using mpich2-1.0.6p1, MPI_TYPE_CREATE_RESIZED produces an error.
> >> Running the following fortran program aborts with the error:
> >> With versions prior to 1.0.5, this programs runs without any error.
> >> Regards,   -Minh.
> >> PROGRAM main
> >>   USE mpi
> >>   IMPLICIT NONE
> >>   INTEGER :: ierr, LINE_TYPE, LINES_TYPE
> >>   INTEGER(MPI_ADDRESS_KIND) :: extent, lb !
> >>   CALL MPI_INIT(ierr)
> >>   CALL MPI_TYPE_VECTOR(10, 1, 10, MPI_INTEGER, LINE_TYPE, ierr)
> >>   CALL MPI_TYPE_COMMIT(LINE_TYPE, ierr) !
> >>   CALL MPI_TYPE_GET_EXTENT(MPI_INTEGER, lb, extent, ierr)
> >>   CALL MPI_TYPE_CREATE_RESIZED(LINE_TYPE, lb, extent, LINES_TYPE,
> >> ierr)
> >>   CALL MPI_TYPE_COMMIT(LINES_TYPE, ierr) !
> >>   CALL MPI_TYPE_GET_EXTENT(LINES_TYPE, lb, extent, ierr)
> >>   PRINT*, 'LINES_TYPE: lb, extent', lb, extent !
> >>   CALL MPI_FINALIZE(ierr)
> >> END PROGRAM main
> Dr. Trach-Minh Tran
> CRPP/SB/EPFL http://crppwww.epfl.ch
> Swiss Federal Institute of Technology
> CH-1015 Lausanne
> Office: http://plan.epfl.ch/?room=PPB111
> Tel: +41 21 693 4569
> Fax: +41 21 693 5176
