[MPICH] Problem with MPI_TYPE_CREATE_RESIZED
Rajeev Thakur thakur at mcs.anl.gov
Sun Feb 10 08:28:42 CST 2008
I can't reproduce the error. What compiler are you using? Also, it may not
matter but it should be integer(kind=MPI_ADDRESS_KIND).
Rajeev
> -----Original Message-----
> From: owner-mpich-discuss at mcs.anl.gov
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Trach-Minh Tran
> Sent: Sunday, February 10, 2008 2:16 AM
> To: MPICH Discuss
> Subject: [MPICH] Problem with MPI_TYPE_CREATE_RESIZED
> Hello,
> Using mpich2-1.0.6p1, MPI_TYPE_CREATE_RESIZED produces an
> error. Running the following fortran program aborts with the error:
> Assertion failed in file dataloop.c at line 554: old_loop_sz > 0
> With versions prior to 1.0.5, this programs runs without any error.
> Regards,   -Minh.
> PROGRAM main
>   USE mpi
>   IMPLICIT NONE
>   INTEGER :: ierr, LINE_TYPE, LINES_TYPE
>   INTEGER(MPI_ADDRESS_KIND) :: extent, lb !
>   CALL MPI_INIT(ierr)
>   CALL MPI_TYPE_VECTOR(10, 1, 10, MPI_INTEGER, LINE_TYPE, ierr)
>   CALL MPI_TYPE_COMMIT(LINE_TYPE, ierr)
>   CALL MPI_TYPE_GET_EXTENT(MPI_INTEGER, lb, extent, ierr)
>   CALL MPI_TYPE_CREATE_RESIZED(LINE_TYPE, lb, extent,
> LINES_TYPE, ierr)
>   CALL MPI_TYPE_COMMIT(LINES_TYPE, ierr) !
>   CALL MPI_TYPE_GET_EXTENT(LINES_TYPE, lb, extent, ierr)
>   PRINT*, 'LINES_TYPE: lb, extent', lb, extent !
>   CALL MPI_FINALIZE(ierr)
> END PROGRAM main
