[MPICH] Problem with MPI_TYPE_CREATE_RESIZED
Trach-Minh Tran
trach-minh.tran at epfl.ch
Sun Feb 10 02:16:26 CST 2008
Hello,
Using mpich2-1.0.6p1, MPI_TYPE_CREATE_RESIZED produces
an error. Running the following fortran program aborts
with the error:
Assertion failed in file dataloop.c at line 554: old_loop_sz > 0
With versions prior to 1.0.5, this programs runs without
any error.
Regards, -Minh.
PROGRAM main
USE mpi
IMPLICIT NONE
INTEGER :: ierr, LINE_TYPE, LINES_TYPE
INTEGER(MPI_ADDRESS_KIND) :: extent, lb
CALL MPI_INIT(ierr)
CALL MPI_TYPE_VECTOR(10, 1, 10, MPI_INTEGER, LINE_TYPE, ierr)
CALL MPI_TYPE_COMMIT(LINE_TYPE, ierr)
CALL MPI_TYPE_GET_EXTENT(MPI_INTEGER, lb, extent, ierr)
CALL MPI_TYPE_CREATE_RESIZED(LINE_TYPE, lb, extent, LINES_TYPE, ierr)
CALL MPI_TYPE_COMMIT(LINES_TYPE, ierr)
CALL MPI_TYPE_GET_EXTENT(LINES_TYPE, lb, extent, ierr)
PRINT*, 'LINES_TYPE: lb, extent', lb, extent
CALL MPI_FINALIZE(ierr)
END PROGRAM main
