[MPICH] MPICH2 with mumps error in a call to MPI_Bcast (INVALID DATATYPE,Invalid communicator)
    Tunc Bahcecioglu
    tuncbah at gmail.com
    Thu Feb  7 07:44:12 CST 2008
Hi
I am trying to make MUMPS run with MPICH2. I send a mail to MUMPS mailing
list but couldn't get an answer.
MPI stops and gives the following error message after a cal to MPI_BCAST
Here NRHS is 0 and COMM is MPI_COMM_WORLD (I don't know if running the
program with mpiexec changes these parameters but the error message does not
change.)
CALL*MPI_BCAST(NRHS,1,MPI_INTEGER,0,mumps_par%COMM,IERR)
*job aborted:**
process: node: exit code: error message:
0: localhost: 1: Fatal error in MPI_Bcast: Invalid communicator, error
stack:
MPI_Bcast(784): MPI_Bcast(buf=0012FA08, count=1, INVALID DATATYPE, root=0,
comm=
0x5b) failed
MPI_Bcast(700): Invalid communicator*
I am using Intel FORTRAN and C++ compilers v10, VSNET2003, and I am running
on a dual core Vista machine.
Any idea about the error message or what I may be doing wrong?
The main code I am trying is an example from mumps so I don't think the
error is in the code by the way.
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080207/c22860be/attachment.htm>
