[MPICH] MPICH2 with MS Vista
Jayesh Krishna
jayesh at mcs.anl.gov
Tue Feb 5 11:37:39 CST 2008
Hmm... Looks like some tightened security with Vista.
When you are installing smpd from command line pass the passphrase as an
option to smpd (smpd -phrase behappy -install). You can find all the options
available with smpd in the windows developer's guide
(http://www.mcs.anl.gov/research/projects/mpich2/documentation/index.php?s=d
ocs).
Jayesh
-----Original Message-----
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Brian Andrus
Sent: Monday, February 04, 2008 7:20 PM
Subject: Re: [MPICH] MPICH2 with MS Vista
Jayesh,
Yes, I installed MPICH2 for all users. I am installing from the only account
on the machine, it is a member of the administrators group.
There is no domain, it is a single stand-alone system. I am pretty certain
it is the ultra-tightened security of vista. I'm just not sure what a proper
work-around would be.
It does seem that I have to run smpd.exe -install from an console that is
run as administrator (in vista, being a member of the administrator group
does not mean you get unfettered access to everything).
This adds the service so I can start it. It also puts the system in a state
where mpiexec can work. I am just unable to get wmpiexe to work. I may have
to 'deal with it', though it does bug me.
Brian
Jayesh Krishna wrote:
> Hi,
> Did you install MPICH2 for all users (Everyone)? During installation
> MPICH2 prompts the user (a radio button) to specify whether MPICH2 is
> installed only for the current user or for "Everyone".
> Are you installing MPICH2 from an admin account and trying to use
> MPICH2 from a non-admin account (or a different account) ?
> Regards,
> Jayesh
> From: owner-mpich-discuss at mcs.anl.gov
> Sent: Monday, February 04, 2008 1:35 PM
> Jayesh,
> No luck. I uninstalled MPICH2, ensured the entry for it was not listed
> in the manage computer->services section and rebooted. I ran the
> installer, used the default passphrase and rebooted after it said it
> was successfully installed.
> Then I opened a command window and ran:
> "\Program Files\MPICH2\bin\mpiexec.exe" -n 1 dir It asks for a
> passphrase and I get an error:
> Please specify an authentication passphrase for smpd:
> Unable to connect to 'Brian-PC:8676',
> sock error: generic socket failure, error stack:
> MPIDU_Sock_post_connect(1228): unable to connect to Brian-PC on port
> 8676, exhausted all endpoints (errno -1)
> MPIDU_Sock_post_connect(1275): unable to connect to Brian-PC on port
> 8676, No connection could be made because the target machine actively
refused it.
> (errno 10061)
> I look at the manage computer->services and MPICH2 is not listed. It
> does not install the smpd service successfully, I think. The only way
> I have been able to see it installed is when I open a command window
> using administrator privileges and running:
> "\Program Files\MPICH2\bin\smpd.exe" -install
> I tried starting the service:
> C:\Users\Brian>"\Program Files\MPICH2\bin\smpd.exe" -start
> OpenSCManager
> failed:
> Access is denied. (error 5)
> So I tried starting it from an admin console:
> C:\Windows\system32>"\Program Files\MPICH2\bin\smpd.exe" -start
> OpenService
> failed:
> The specified service does not exist as an installed service. (error
> 1060)
> It seems the installer is not installing the service as would be
> expected under Windows Vista Home Ultimate.
> At least not on my new Dell XPS 410.
> I can force the install using smpd.exe -install, but I am still unable
> to use wmpiexec (I am able to use mpiexec somewhat).
> Brian
>> Hi,
>> The smpd passphrase is the passphrase that the user specifies
>> during the
>> MPICH2 installation process (By default the passphrase is set to
"behappy"
>> and the user has the option of changing it. The user is prompted for
>> the same during the MPICH2 installation).
>> You don't have to run "smpd.exe -install" to get smpd running on
>> your system. During a successful installation this is done for you by
>> the installer.
>> I would recommend that you re-install MPICH2 on your system (after
>> uninstalling the existing version of MPICH2). Please try rebooting
>> your system before running mpiexec. Initially try running some simple
>> command like "mpiexec -n 1 dir". Then try running "mpiexec -n 2
>> cpi.exe" (cpi.exe is provided with 32-bit version of MPICH2 in
>> <INSTALL-DIR>\MPICH2\examples
>> directory)
>> Regards,
>> Jayesh
>> Sent: Sunday, February 03, 2008 2:24 AM
>> Subject: [MPICH] MPICH2 with MS Vista
>> I am trying to get MPICH2 working all around with MS Vista. I have
>> installed it and I can get a simple hello world to run in the
>> console, but I would like to use wmpiexec to run things too.
>> Unfortunately, every time I try to run my hello world, I get an error:
>> Error: No smpd passphrase specified through the registry or .smpd
>> file, exiting.
>> When I run wmpiconfig and try to scan hosts, I get:
>> Please specify an authentication passphrase for smpd: 1.0.6
>> I run wmpiregister and use my logged in username/password, which
>> seems to register (wmpiconfig runs this automatically if there is no
>> account/pass in the registry).
>> I noticed a few things:
>> 1) I cannot run the installer as an administrator (the option isn't
>> there when I right click on a .msi file)
>> 2) After the install, I needed to open a console administrator and
>> then run "smpd.exe -install" to get the MPICH2 process manager
>> service registered, otherwise it would not show up under the services.
>> 3) As a normal user, I can run my hello world from a command windows,
>> if I have added a user/password using wmpiregister. To do so, I have
>> to just hit return when it asks for a passphrase.
>> --------------------------snip-------------------------------------
>> C:\Users\Brian>"\Program Files\MPICH2\bin\mpiexec.exe" -n 2
>> "\Users\Brian\Documents\Visual Studio
>> 2008\Projects\HelloWorld\Debug\HelloWorld.exe"
>> Hello World from process 0 on Brian-PC Number of Processes: 2 Hello
>> World from process 1 on Brian-PC
>> I used MS Visual C++ express 2008 to create my hello world program. I
>> did need to set up a couple paths to get the mpi.h libraries included
>> so it would compile and link, but it seems to be working and
>> generating executable code.
>> This is all on a fresh Dell with Vista Home Ultimate installed.
>> Any ideas what I am missing to get wmpiexec to work?
>> Thanks in advance,
>> Brian Andrus
> This message has been scanned for viruses and dangerous content by
> MailScanner, and is believed to be clean.
