[MPICH] MPICH2 with MS Vista
Brian Andrus
brian.andrus at firstspot.net
Sun Feb 3 02:23:30 CST 2008
I am trying to get MPICH2 working all around with MS Vista. I have
installed it and I can get a simple hello world to run in the console,
but I would like to use wmpiexec to run things too. Unfortunately, every
time I try to run my hello world, I get an error:
Error: No smpd passphrase specified through the registry or .smpd file,
exiting.
When I run wmpiconfig and try to scan hosts, I get:
Please specify an authentication passphrase for smpd: 1.0.6
I run wmpiregister and use my logged in username/password, which seems
to register (wmpiconfig runs this automatically if there is no
account/pass in the registry).
I noticed a few things:
1) I cannot run the installer as an administrator (the option isn't
there when I right click on a .msi file)
2) After the install, I needed to open a console administrator and then
run "smpd.exe -install" to get the MPICH2 process manager service
registered, otherwise it would not show up under the services.
3) As a normal user, I can run my hello world from a command windows, if
I have added a user/password using wmpiregister. To do so, I have to
just hit return when it asks for a passphrase.
--------------------------snip-------------------------------------
C:\Users\Brian>"\Program Files\MPICH2\bin\mpiexec.exe" -n 2
"\Users\Brian\Documents\Visual Studio
2008\Projects\HelloWorld\Debug\HelloWorld.exe"
Hello World from process 0 on Brian-PC
Number of Processes: 2
Hello World from process 1 on Brian-PC
I used MS Visual C++ express 2008 to create my hello world program. I
did need to set up a couple paths to get the mpi.h libraries included so
it would compile and link, but it seems to be working and generating
executable code.
This is all on a fresh Dell with Vista Home Ultimate installed.
Any ideas what I am missing to get wmpiexec to work?
Thanks in advance,
Brian Andrus
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.
