[mpich-discuss] mpich2 1.0.8: problems compiling  (simplemake)
    Bellanca Gaetano
    gaetano.bellanca at unife.it
    Tue Dec 30 02:18:46 CST 2008
Hi Rajeev,
I'm sorry but I don't completely understand what did you mean.
I'm on a local disk of a remote machine (I'm at home, and the
computer is at the University). I rebooted the machine (to be sure
that everything is O.K. also after the last update). But I have the same error.
The mpich2 directory is a fresh untar. I only changed the name from
mpich2-1.0.8 to mpich2-1.0.8_gnu to distinguish between the gfortran
and the pgi compilations. But I also try with the original name ....
without solving the problem.
Gaetano
  At 05.17 30/12/2008, you wrote:
>It is probably a problem with time stamps being out of sync on the
>machine. Try starting with a fresh untar of the tarball. Do it on a local disk
>instead of an NFS file system.
>Rajeev
>From: mpich-discuss-bounces at mcs.anl.gov
>[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Bellanca Gaetano
>Sent: Monday, December 29, 2008 5:49 PM
>To: mpich-discuss at mcs.anl.gov
>Subject: [mpich-discuss] mpich2 1.0.8: problems compiling (simplemake)
>Hi,
>I'm having problems in compiling mpich2 1.0.8 with a pgi 8.0.1
>fortran compiler on an ubuntu 7.10 linux box (32 bit).
>The same problems is reported also with a gnu compiler, whereas the
>code compile correctly with Intel 10.1.
>The error is:
>>make[2]: Entering directory
>>`/home/bellanca/software/mpich2/1.0.8/mpich2-1.0.8_pgi/src/mpid'
>>( cd . && /maint/simplemake \
>>         -rootdir=../../ \
>>         -configdir=. \
>>         -common=/maint/makedefs \
>>         -docnamedefs=/maint/docnotes \
>>         "-autoconf=-I ROOTDIR/confdb" \
>>         -libdir='${MPILIBNAME}=ROOTDIR/lib' \
>>         -smroot=/maint \
>>         -distcleanfiles="Makefile" \
>>         -smvar_doc_attop=0 \
>>                 Makefile.sm )
>>/bin/bash: line 1: /maint/simplemake: No such file or directory
>>make[2]: *** [Makefile.in] Error 127
>This is what I have configured before compiling mpich2:
>>./configure --prefix=/opt/mpich2/1.0.8/pgi --enable-cxx
>>--enable-f90 --enable-fast --enable-traceback --with-mpe
>>--enable-f90modules --enable-cache --enable-romio
>>--with-file-system=nfs+ufs+pvfs2 --with-device=ch3:nemesis
>>--with-pvfs2=/usr/local --with-java=/usr/lib/jvm/java-6-sun
>Any idea?
>Regards.
>Gaetano
Gaetano Bellanca - Department of Engineering - University of Ferrara
Via Saragat, 1 - 44100 - Ferrara - ITALY
Voice (VoIP):  +39 0532 974809     Fax:  +39 0532 974870
mailto:gaetano.bellanca at unife.it
"L'istruzione costa? Stanno provando con l'ignoranza!"
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20081230/efd1eb36/attachment.htm>
