[mpich-discuss] Trouble with new installation -- failed	to	connect to mpd
    Rajeev Thakur
    thakur at mcs.anl.gov
    Mon Dec  1 13:01:33 CST 2008
This means a simple client on one machine was not able to connect to a
simple server on another machine in the cluster (independent of MPICH or
MPD). Can you check the networking settings on the machines. Is there a
firewall preventing access?
Rajeev
> -----Original Message-----
> From: mpich-discuss-bounces at mcs.anl.gov
> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of
> Benjamin Svetitsky
> Sent: Monday, December 01, 2008 9:42 AM
> To: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] Trouble with new installation --
> Thanks, Dave.  mpdcheck indeed points to a problem.  But the
> message is
> not very illuminating, apart from pointing out which links are giving
> trouble.  What really has me worried is that mpdcheck gives me the
> *same* error message on my old cluster -- where MPICH has
> been working
> fine for a year!  The message:
> [root at nodeF ~]# mpdcheck -f mpd.hosts -ssh
> client on nodeE failed to access the server
> here is the output:
> Traceback (most recent call last):
>    File "/usr/local/bin/mpdcheck.py", line 103, in ?
>      sock.connect((argv[argidx+1],int(argv[argidx+2])))  #
> note double
> parens
>    File "<string>", line 1, in connect
> socket.error: (113, 'No route to host')
> Dave Goodell wrote:
> > Hi Ben,
> > Please try the MPD troubleshooting steps listed in appendix
> A of the
> > install guide:
> http://www.mcs.anl.gov/research/projects/mpich2/documentation/
> files/mpich2-1.0.8-installguide.pdf
> > In particular, the mpdcheck utility should give you a
> better clue about
> > where the problem is.
> > -Dave
> > On Dec 1, 2008, at 4:11 AM, Benjamin Svetitsky wrote:
> >> Dear MPI community,
> >> I already have MIPCH 1.0.8 running well on a cluster of four Linux
> >> quad cores.  But now I can't get it running on a new
> cluster.  I think
> >> I installed everything exactly like the first system.  But
> when I try
> >> to mpdboot as root I get a minimal error message:
> >> [root at nodeE ~]# mpdboot -n 4 -f /root/mpd.hosts
> >> mpdboot_nodeE (handle_mpd_output 401): failed to connect
> to mpd on nodeF
> >> The /root/mpd.hosts contains:
> >> nodeE
> >> nodeF
> >> nodeG
> >> nodeH
> >> Oddly enough, after the failure of mpdboot as above I find:
> >> [root at nodeE ~]# mpdtrace
> >> nodeE
> >> nodeF
> >> If I do mpdallexit and log into nodeF, the result is:
> >> [root at nodeF ~]# mpdboot -n 4 -f /root/mpd.hosts
> >> mpdboot_nodeF (handle_mpd_output 392): failed to handshake
> with mpd on
> >> nodeE; recvd output={}
> >> Do I have a network problem or is it an MPICH problem?
> >> Thanks,
> >>     Ben
> >> Prof. Benjamin Svetitsky         Phone:            +972-3-640 8870
> >> School of Physics and Astronomy  Fax:              +972-3-640 7932
> >> Tel Aviv University              E-mail:      bqs at julian.tau.ac.il
> >> 69978 Tel Aviv, Israel           WWW: http://julian.tau.ac.il/~bqs
