[mpich-discuss] Trouble with new installation -- failed to connect to mpd
Benjamin Svetitsky
bqs at julian.tau.ac.il
Mon Dec 1 09:42:11 CST 2008
Thanks, Dave. mpdcheck indeed points to a problem. But the message is
not very illuminating, apart from pointing out which links are giving
trouble. What really has me worried is that mpdcheck gives me the
*same* error message on my old cluster -- where MPICH has been working
fine for a year! The message:
[root at nodeF ~]# mpdcheck -f mpd.hosts -ssh
client on nodeE failed to access the server
here is the output:
Traceback (most recent call last):
File "/usr/local/bin/mpdcheck.py", line 103, in ?
sock.connect((argv[argidx+1],int(argv[argidx+2]))) # note double
parens
File "<string>", line 1, in connect
socket.error: (113, 'No route to host')
Dave Goodell wrote:
> Hi Ben,
> Please try the MPD troubleshooting steps listed in appendix A of the
> install guide:
> http://www.mcs.anl.gov/research/projects/mpich2/documentation/files/mpich2-1.0.8-installguide.pdf
> In particular, the mpdcheck utility should give you a better clue about
> where the problem is.
> -Dave
> On Dec 1, 2008, at 4:11 AM, Benjamin Svetitsky wrote:
>> Dear MPI community,
>> I already have MIPCH 1.0.8 running well on a cluster of four Linux
>> quad cores. But now I can't get it running on a new cluster. I think
>> I installed everything exactly like the first system. But when I try
>> to mpdboot as root I get a minimal error message:
>> [root at nodeE ~]# mpdboot -n 4 -f /root/mpd.hosts
>> mpdboot_nodeE (handle_mpd_output 401): failed to connect to mpd on nodeF
>> The /root/mpd.hosts contains:
>> nodeE
>> nodeF
>> nodeG
>> nodeH
>> Oddly enough, after the failure of mpdboot as above I find:
>> [root at nodeE ~]# mpdtrace
>> nodeE
>> nodeF
>> If I do mpdallexit and log into nodeF, the result is:
>> [root at nodeF ~]# mpdboot -n 4 -f /root/mpd.hosts
>> mpdboot_nodeF (handle_mpd_output 392): failed to handshake with mpd on
>> nodeE; recvd output={}
>> Do I have a network problem or is it an MPICH problem?
>> Thanks,
>> Ben
>> Prof. Benjamin Svetitsky Phone: +972-3-640 8870
>> School of Physics and Astronomy Fax: +972-3-640 7932
>> Tel Aviv University E-mail: bqs at julian.tau.ac.il
>> 69978 Tel Aviv, Israel WWW: http://julian.tau.ac.il/~bqs
