[mpich-discuss] Fatal error in MPI_Finalize: Other MPI error, error stack:
Hisham Adel hosham2004 at yahoo.com
Sun Aug 31 04:08:12 CDT 2008
hi,
I have managed DNS to see the other node and it can ping it and can share files with it but it give me the same error then I removed DNS and it also give me the same error.
I am working on windows server 2003.
any other ideas please...
thanks in advance....
Hisham Adel
--- On Thu, 8/28/08, Jayesh Krishna <jayesh at mcs.anl.gov> wrote:
Subject: RE: [mpich-discuss] Fatal error in MPI_Finalize: Other MPI error, error stack:
To: "'Hisham Adel'" <hosham2004 at yahoo.com>
Cc: mpich-discuss at mcs.anl.gov, "'MPI'" <mpich2-dev at mcs.anl.gov>
Date: Thursday, August 28, 2008, 5:50 PM
        The
description of error code 11004 in MS docs
is,
The
requested name is valid and was found in the database, but it does not have the
correct associated data being resolved for. The usual example for this is a host
name-to-address translation attempt (using gethostbyname or
WSAAsyncGetHostByName) which uses the DNS (Domain Name Server). An MX record is
returned but no A record—indicating the host itself exists, but is not directly
reachable.
Looks like the DNS server for your machine does not have information about the
computers/hosts in your setup.
Jayesh
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Hisham
Adel
Sent: Thursday, August 28, 2008 2:43 AM
To: MPI;
MPI_questions
Subject: [mpich-discuss] Fatal error in MPI_Finalize:
      I am using MPICH2 on windows. There is a program called
      Hello2.exe it only show the computer name.
      it gives me the required results but with errors i dont know the
      resons.
      also when i try to use MPI_Send and MPI_Recv it dont give me any
      response.
      can any one help me.
      Here is the results
C:\Program Files\MPICH2\bin>mpiexec -machinefile hosts.txt -n
      2 Hello2.exe
node1
node2.NU
MPI_Finalize(255)............: MPI_Finalize
      failed
MPI_Finalize(154)............:
MPID_Finalize(94)............:
MPI_Barrier(406).............:
      MPI_Barrier(comm=0x44000002)
      failed
MPIR_Barrier(77).............:
MPIC_Sendrecv(120)...........:
MPID_Isend(103)..............:
      failure occurred while attempting to send an eage
r
      message
MPIDI_CH3_iSend(172).........:
MPIDI_CH3I_Sock_connect(1191):
      [ch3:sock] rank 0 unable to connect to rank 1 usi
ng business card
      <port=1327 description=node2.NU ifname=192.168.10.21
MPIDU_Sock_post_connect(1228): unable to connect to node2.NU on
      port 1327, exhau
sted all endpoints (errno
      -1)
MPIDU_Sock_post_connect(1244): gethostbyname failed, The requested
      name is valid
, but no data of the requested type was found. (errno
      11004)
job aborted:
rank: node: exit code[: error message]
0:
      node1: 1: Fatal error in MPI_Finalize: Other MPI error, error
      stack:
      failed
      failed
r
      message
ng business card
      port 1327, exhau
      -1)
      name is valid
      11004)
1: node2: 1
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080831/73c3c3e6/attachment.htm>
