[mpich-discuss] Fatal error in MPI_Finalize: Other MPI error, error stack:
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Thu Aug 28 09:50:25 CDT 2008
        The description of error code 11004 in MS docs is,
The requested name is valid and was found in the database, but it does not
have the correct associated data being resolved for. The usual example for
this is a host name-to-address translation attempt (using gethostbyname or
WSAAsyncGetHostByName) which uses the DNS (Domain Name Server). An MX
record is returned but no A record-indicating the host itself exists, but
is not directly reachable.
        Looks like the DNS server for your machine does not have
information about the computers/hosts in your setup.
Jayesh
  _____
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Hisham Adel
Sent: Thursday, August 28, 2008 2:43 AM
To: MPI; MPI_questions
Subject: [mpich-discuss] Fatal error in MPI_Finalize: Other MPI error,
error stack:
I am using MPICH2 on windows. There is a program called Hello2.exe it only
show the computer name.
it gives me the required results but with errors i dont know the resons.
also when i try to use MPI_Send and MPI_Recv it dont give me any response.
can any one help me.
Here is the results
C:\Program Files\MPICH2\bin>mpiexec -machinefile hosts.txt -n 2 Hello2.exe
node1
node2.NU
MPI_Finalize(255)............: MPI_Finalize failed
MPI_Finalize(154)............:
MPID_Finalize(94)............:
MPI_Barrier(406).............: MPI_Barrier(comm=0x44000002) failed
MPIR_Barrier(77).............:
MPIC_Sendrecv(120)...........:
MPID_Isend(103)..............: failure occurred while attempting to send
an eage
r message
MPIDI_CH3_iSend(172).........:
MPIDI_CH3I_Sock_connect(1191): [ch3:sock] rank 0 unable to connect to rank
1 usi
ng business card <port=1327 description=node2.NU ifname=192.168.10.21 >
MPIDU_Sock_post_connect(1228): unable to connect to node2.NU on port 1327,
exhau
sted all endpoints (errno -1)
MPIDU_Sock_post_connect(1244): gethostbyname failed, The requested name is
valid
, but no data of the requested type was found. (errno 11004)
job aborted:
rank: node: exit code[: error message]
0: node1: 1: Fatal error in MPI_Finalize: Other MPI error, error stack:
an eage
r message
1 usi
exhau
valid
1: node2: 1
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080828/aad83b94/attachment.htm>
