[mpich-discuss] child node can't contact parent?
Jayesh Krishna
jayesh at mcs.anl.gov
Thu Aug 28 15:58:13 CDT 2008
Great! Let us know if you need any further help.
Jayesh
-----Original Message-----
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Tony Bathgate
Sent: Thursday, August 28, 2008 3:39 PM
Subject: Re: [mpich-discuss] child node can't contact parent?
Thanks for the help! Everything I've tried is working without a hitch now.
To solve the DNS problem I simply rejoined the computers with the rest of
our work network. Earlier while it was on the network I was having
permission issues but to fix that I registered the local Administrator
account with mpiexec, but still log on and make mpi calls through my
network account (which I didn't realize you could do). I'm still a little
wary about leaving holes in the firewall while its on the work network
(just a set of open ports using the MPICH_PORT_RANGE variable), but its
working and that's more important to me right now.
Thanks again,
Tony
Jayesh Krishna wrote:
> Hi,
> The description of error code 11004 in MS docs is,
> The requested name is valid and was found in the database, but it does
> not have the correct associated data being resolved for. The usual
> example for this is a host name-to-address translation attempt (using
> gethostbyname or WSAAsyncGetHostByName) which uses the DNS (Domain
> Name Server). An MX record is returned but no A record-indicating the
> host itself exists, but is not directly reachable.
> Looks like the DNS server for your machine does not have information
> about the computers/hosts in your setup.
> Regards,
> Jayesh
> From: owner-mpich-discuss at mcs.anl.gov
> Sent: Wednesday, August 27, 2008 6:28 PM
> To: Jayesh Krishna
> Cc: mpich-discuss at mcs.anl.gov
> Hi,
> Thanks for the reply.
> I had actually already pinged Computer1 from Computer2 and vice versa.
> The ping works fine. I tried using hostname with mpiexec like you
> suggested and it works fine too, from both computers. Now I'm baffled.
> I also tried your Hello World program and it crashed. Here's the error
> messages I got:
> C:\helloworld\Debug\> mpiexec -hosts 2 192.168.5.100 192.168.5.200
> helloworld.exe Fatal error in MPI_Finalize: Other MPI error, error
stack:
> MPI_Finalize<255>............: MPI_Finalize failed
> MPI_Finalize<154>............:
> MPID_Finalize<94>............:
> MPI_Barrier<406>.............: MPI_Barrier <comm=0x44000002>
> MPIR_Barrier<77>.............:
> MPIC_Sendrecv<120>...........:
> MPID_Isend<103>..............: failure occured while attempting to
> send an eager message
> MPIDI_CH3_iSend<172>.........:
> MPIDI_CH3I_Sock_connect<1191>: unable to connect to rank 0 using
> business card <port=8673 description=computer1.usask.ca
> ifname=192.168.5.100>
> MPIDU_Sock_post_connect<1244>: gethostbyname failed, The requested
> name is valid, but no data of the requested type was found. <errno
> 11004> job aborted:
> rank: node: exit code[: error message]
> 0: 192.168.5.100: 1
> 1: 192.168.5.200: 1: Fatal error in MPI_Finalize: Other MPI error,
> error
> stack:
> MPIDI_CH3I_Sock_connect<1191>: unable to connect to rank 1 using
> 11004>
> So it seems to me that it can execute programs remotely but not when
> the program relies on the MPICH2 c implementation libraries. Does that
> make sense, and how could it be remedied?
> Thanks again,
> Tony
> > Hi,
> > Looks like something is wrong with the setup of your machines.
> > # Can you ping from one machine to the other ?
> > - From Computer1 try pinging Computer2
> > - From Computer2 try pinging Computer1
> > # Start debugging by running a non-MPI program (like hostname)
> > mpiexec -hosts 2 IPAddress_Of_Computer1 IPAddress_Of_Computer2
> > hostname
> > # Then debug with a simple hello world program (don't debug your
> > setup with a complex program)
> > ----------------- hello world --------------- #include <stdio.h>
> > #include "mpi.h"
> > int main(int argc, char *argv[]){
> > int rank=-1;
> > MPI_Init(&argc, &argv);
> > MPI_Comm_rank(MPI_COMM_WORLD, &rank); printf("[%d] Hello world\n",
> > rank); MPI_Finalize(); }
> > Let us know the results.
> > Regards,
> > Jayesh
> > Sent: Wednesday, August 27, 2008 3:31 PM
> > Subject: [mpich-discuss] child node can't contact parent?
> > Hi All,
> > I apologize in advance for the length of this email; I'm new to the
> > world of MPI and I want to include everything that might be relevant.
> > I have the Win32 IA32 binary of MPICH2 installed on two machines.
> > They are running Windows XP Pro. x64 Edition with Service Pack 2 and
> > they each have an Intel Xeon processor. To simplify things I took
> > them off our network, gave them their own router, and dropped their
> > Windows firewalls. I have assigned the machines static IP's with the
> > router (192.168.5.100 for Computer1, and 192.168.5.200 for Computer2).
> > I've registered the local Administrator accounts (which have
> > identical passwords and credentials) with mpiexec on each machine.
> > And everything below was attempted from the Administrator account.
> > I've tried running the cpi.exe example but it just hangs:
> > C:\Program Files (x86)\MPICH2\examples> mpiexec -hosts 2 Computer1
> > Computer2 .\cpi.exe
> > Enter the number of intervals: (0 quits) 1
> > (here I waited about 20 minutes, then Ctrl+C)
> > mpiexec aborting job
> > job aborted:
> > 0: Computer1: 123: mpiexec aborting job
> > 1: Computer2: 123
> > It runs perfectly fine if I have it execute it with the -localonly
tag.
> > To explore this issue I wrote a simple program that uses
> > MPI_Comm_spawn to spawn a worker program. The master then sends the
> > worker a message and they both exit. The manager node runs the code
> > that follows here:
> > #include <mpi.h>
> > #include <stdio.h>
> > int main (int argc, char* argv[])
> > int someVariable = 10;
> > MPI_Info info;
> > MPI_Comm workercomm;
> > MPI_Request request;
> > MPI_Status status;
> > MPI_Init( &argc, &argv );
> > fprintf( stdout, "In Master - someVariable = %i \n", someVariable );
> > fflush( stdout );
> > MPI_Info_create( &info );
> > MPI_Info_set( info, "host", "Computer2" ); MPI_Comm_spawn(
> > "C:\\MPIworker\\Debug\\MPIworker.exe",
> > MPI_ARGV_NULL,
> > 1, info, 0, MPI_COMM_SELF, &workercomm, MPI_ERRCODES_IGNORE );
> > MPI_Info_free( &info );
> > MPI_Isend( &someVariable, 1, MPI_INT, 0, 0, workercomm,
> > &(request) );
> > MPI_Waitall( 1, request, status );
> > fprintf(stdout,"Done sending\n");
> > fflush(stdout);
> > MPI_Finalize();
> > return 0;
> > The worker code follows here:
> > #include <mpi.h>
> > #include <stdio.h>
> > int someVariable = 0;
> > MPI_Comm parentcomm;
> > MPI_Status status;
> > fprintf(stdout, "In Worker: Before receive - someVariable = %i
> > \n",someVariable); fflush( stdout );
> > MPI_Comm_get_parent( &parentcomm );
> > MPI_Irecv( &someVariable, 1, MPI_INT, 0, 0, parentcomm, &request );
> > MPI_Wait( &request, &status );
> > fprintf( stdout, "After receive - someVariable = %i\n", someVariable
> > MPI_Finalize();
> > return 0;
> > When I run this code I get the following results:
> > C:\MPImanager\Debug\> mpiexec -n 1 MPImanager.exe In Master -
> > someVariable = 10 Fatal error in MPI_Init: Other MPI error, error
> > stack:
> > MPIR_Init_thread<294>............................:Initialization
> > failed
> > MPID_Init<242>...................................:Spawned process
> > group was unable to connect back to parent on port <tag=0 port=8673
> > description=computer1.usask.ca ifname=192.168.5.100>
> > MPID_Comm_connect<187>...........................:
> > MPIDI_Comm_connect<369>..........................:
> > MPIDI_Create_inter_root_communicator_connect<133>:
> > MPIDI_CH3I_Connect_to_root_sock<289>.............:
> > MPIDU_Sock_post_connect<1228>....................: unable to connect
> > to computer1.usask.ca on port 8673, exhuasted all endpoints <errno
> > -1>
> > MPIDU_Sock_post_connect<1244>....................: gethostbyname
> > failed, The requested name is valid, but no data of the requested
> > type was found. <errno 11004>
> > Job aborted:
> > 0: computer2: 1: fatal error in MPI_Init: other MPI error, error
> > stack:
> > failed
> > -1>
> > (Here I waited several minutes before pressing ctrl+c)
> > mpiexec aborting job ...
> > (Here I waited several more minutes before pressing ctrl+c and
> > returning to the command prompt)
> > So the program is able to spawn a process on the worker, but then
> > when the worker is unable to contact the manager node MPI_Init
> > fails. The error stack shows that it has the correct IP address and
> > tries to use port 8673. At first I thought the problem might be that
> > it was appending the domain name (usask.ca) from their old network,
> > but the IP address is still correct so now I'm not sure.
> > If I change the code so Computer2 is the manager and Computer1 is
> > the worker the results are the same. But just like cpi.exe if I
> > confine both the worker and the manager to the local host it
> > performs perfectly. I assume this is an issue with either the way
> > I've set up my network, or the way I've set up MPICH2 on the
> > computers. Does anyone know what would cause an error like this?
Tony Bathgate
BEng Engineering Physics
BSc Computer Science
Master's Candidate
University of Saskatchewan
116 Science Place
Saskatoon SK,
S7N 5E2
966-6452
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080828/68ff3a7c/attachment.htm>
