[mpich-discuss] working on a process using gdb
Calin Iaru calin at dolphinics.com
Wed Aug 27 05:30:00 CDT 2008
I notice that "show env" command when starting mpiexec -gdb reports some
false values; for instance, the HOSTNAME is set always to one machine,
instead of the machines that are running the processes. On the other hand,
MPD_JRANK varies as it should. This scenario occurs with Linux and mpd as
process manager.
I am interested when debugging to execute some debugging commands only on
one process. For instance, printing the stack iterator is done like this:
0,3-8,10:  (gdb) print i
0:  $2 = 3
3-8:  $2 = 0
0,3-8:  (gdb) 10:  $2 = 2
Is there a way to specify the process on which I would like to run the
command?
