[mpich-discuss] mpdboot fails
Darius Buntinas
buntinas at mcs.anl.gov
Tue Aug 26 18:18:21 CDT 2008
I'm not sure mpdboot supports that scenario. I believe mpd must be in
the same location on all machines. You can try adding it to your path
on each machine.
Otherwise, you can start the mpds by hand:
On one node start mpd in the background:
/path/to/mpd &
Then find the port number it's using:
/path/to/mpdtrace -l
It should output something like:
iMac.local_37896 (127.0.0.1)
On the other nodes start mpd and tell it where to connect:
/path/to/mpd -h iMac.local -p 37896 &
Now, mpdtrace should show you all of the nodes.
Hope this helps.
-d
On 08/26/2008 06:04 PM, Robert Kubrick wrote:
> I'm not clear on how --mpd works: I want to specify two different paths,
> one for the local machine and one for the remote host (or possibly a
> number of different remote hosts). Here it looks like I can only set one
> path for all the hosts:
> $ mpdboot --verbose --totalnum=2 --mpd=/usr/local/mpich2/bin/mpd --debug
> debug: starting
> running mpdallexit on iMac.local
> LAUNCHED mpd on iMac.local via
> debug: launch cmd= /usr/local/mpich2/bin/mpd --ncpus=1 -e -d
> debug: mpd on iMac.local on port no_port
> mpdboot_iMac.local (handle_mpd_output 406): from mpd on iMac.local,
> invalid port info:
> no_port
> $ mpdboot --verbose --totalnum=2 --debug
> debug: starting
> debug: launch cmd= /opt/local/mpich2/bin/mpd.py --ncpus=1 -e -d
> debug: mpd on iMac.local on port 62629
> RUNNING: mpd on iMac.local
> debug: info for running mpd: {'ncpus': 1, 'list_port': 62629,
> 'entry_port': '', 'host': 'iMac.local', 'entry_host': '', 'ifhn': ''}
> LAUNCHED mpd on wlaptop via iMac.local
> debug: launch cmd= ssh -x -n -q wlaptop '/opt/local/mpich2/bin/mpd.py
> -h iMac.local -p 62629 --ncpus=1 -e -d'
> debug: mpd on wlaptop on port no_port
> mpdboot_iMac.local (handle_mpd_output 406): from mpd on wlaptop, invalid
> port info:
> no_port
> On Aug 25, 2008, at 2:20 PM, Rajeev Thakur wrote:
>>> The path to mpd on 'wlaptop' is actually a different one than on
>>> iMac.local. How can I specify a different remote path for mpd?
>> With the --mpd option to mpdboot.
>> Rajeev
>>> -----Original Message-----
>>> From: owner-mpich-discuss at mcs.anl.gov
>>> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Robert Kubrick
>>> Sent: Sunday, August 24, 2008 5:19 PM
>>> To: mpich-discuss at mcs.anl.gov
>>> Subject: [mpich-discuss] mpdboot fails
>>> mpdboot fails when I try to run with this command:
>>> # mpdboot --totalnum=2 --verbose -d debug: starting
>>> debug: mpd on iMac.local on port 61785
>>> debug: info for running mpd: {'ncpus': 1, 'list_port': 61785,
>>> mpd.py -h iMac.local -p 61785 --ncpus=1 -e -d'
>>> invalid port info:
>>> no_port
