[mpich-discuss] cannot set the ring in fedora 8
Waruna Ranasinghe
Waruna.Ranasinghe at uom.lk
Wed Aug 13 00:05:52 CDT 2008
Hi all,
I'm trying to setup MPICH2 in Fedora 8
I execute the command, 'mpd &' in the main node. Then 'mpdtrace -l' gave
localhost.localdomain_40529
then I execute the command 'mpd -h 10.8.102.28 -p 40529 &' in the other node.
Where 10.8.102.28 is the main node.
it gives the following error.
in the node
[cig4 at localhost ~]$ localhost.localdomain_42273 failed ; cause: ('u', 'n', 'a',
'b', 'l', 'e', ' ', 't', 'o', ' ', 'o', 'b', 't', 'a', 'i', 'n', ' ', 's', 'o',
'c', 'k', 'e', 't', ' ', 'f', 'o', 'r', ' ', 'r', 'h', 's', ' ', 'i', 'n', ' ',
'r', 'i', 'n', 'g', '\n', ' ', ' ', ' ', ' ', 't', 'r', 'a', 'c', 'e', 'b', 'a',
'c', 'k', ':', ' ', '[', '(', "'", '/', 'h', 'o', 'm', 'e', '/', 'c', 'i', 'g',
'4', '/', 'm', 'p', 'i', 'c', 'h', '2', '-', 'i', 'n', 's', 't', 'a', 'l', 'l',
'/', 'b', 'i', 'n', '/', 'm', 'p', 'd', "'", ',', ' ', "'", '1', '1', '9', '2',
"'", ',', ' ', "'", '_', 'e', 'n', 't', 'e', 'r', '_', 'e', 'x', 'i', 's', 't',
'i', 'n', 'g', '_', 'r', 'i', 'n', 'g', "'", ')', ',', ' ', '(', "'", '/', 'h',
'o', 'm', 'e', '/', 'c', 'i', 'g', '4', '/', 'm', 'p', 'i', 'c', 'h', '2', '-',
'i', 'n', 's', 't', 'a', 'l', 'l', '/', 'b', 'i', 'n', '/', 'm', 'p', 'd', "'",
',', ' ', "'", '1', '7', '3', "'", ',', ' ', "'", '_', 'm', 'p', 'd', '_', 'i',
'n', 'i', 't', "'", ')', ',', ' ', '(', "'", '/', 'h', 'o', 'm', 'e', '/', 'c',
'i', 'g', '4', '/', 'm', 'p', 'i', 'c', 'h', '2', '-', 'i', 'n', 's', 't', 'a',
'l', 'l', '/', 'b', 'i', 'n', '/', 'm', 'p', 'd', "'", ',', ' ', "'", '1', '3',
'7', '4', "'", ',', ' ', "'", '<', 'm', 'o', 'd', 'u', 'l', 'e', '>', "'", ')',
in the main node
localhost.localdomain_40529 (_handle_rhs_input 870) : re -entering ring
I need your help.
thank you.
Waruna Ranasinghe
This message was sent using IMP, the Internet Messaging Program.
