[mpich-discuss] Socket error on Quad-core Windows XP
Jayesh Krishna jayesh at mcs.anl.gov
Mon Apr 14 15:18:59 CDT 2008
 Run your MPI program as "mpiexec -n 3 simple.exe" (Or to use all the 4
cores/procs - "mpiexec -n 4 simple.exe").
Jayesh
-----Original Message-----
Sent: Monday, April 14, 2008 2:44 PM
To: Jayesh Krishna
Subject: RE: [mpich-discuss] Socket error on Quad-core Windows XP
If you can tell me of another way to access the 4 cores on my machine, I'll
try it.
Gib
Quoting Jayesh Krishna <jayesh at mcs.anl.gov>:
>  Hi,
>   Is there any reason you want to use the "-localonly" option ?
> (PS: The "closesocket()" errors that you see are due to a subtle bug
> in the smpd state machine where a socket is closed twice. This should
> not affect your program. We will fix this bug in the next release.
> These messages show up since you are using the "-localonly" option.)
> Regards,
> Jayesh
> From: owner-mpich-discuss at mcs.anl.gov
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Gib Bogle
> Sent: Sunday, April 13, 2008 8:13 PM
> To: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] Socket error on Quad-core Windows XP
> I am running on an Intel Core 2 Quad CPU Q6600 PC, under Windows XP.
> I simply downloaded and installed the latest binary distribution for
> Windows, mpich2-1.0.7-win32-ia32.msi.  There was no configuration that I
noticed.
> The process manager is smpd, which is started automatically.
> The invocation of my program is:
> mpiexec -localonly 3 simple.exe
> A simple version of the code follows.  I found a couple of interesting
> things.  There are many more 10093 errors with 3 processors than with 4.
> Uncommenting the deallocate statement in the main program seems to
> eliminate
> 10093 errors, but I still get the occasional 10058 error.  It seems
> that
> MPICH2 gets upset if memory allocated after MPI_INIT() is not
> deallocated before MPI_FINALIZE().  Note that errors occur
> intermittently - not every run.
> Cheers
> Gib
> Code:
> ! FILE: simple.f90
> ! This exhibits socket errors
> module mpitest
> use mpi
> IMPLICIT NONE
> integer, parameter :: NDATA = 100
> integer, parameter :: NX = 50, NY = NX, NZ = NX
> type occupancy_type
>      integer :: cdata(NDATA)
> end type
> type(occupancy_type), allocatable :: occupancy(:,:,:) integer :: me,
> my_cell_type
> contains
> subroutine mpi_initialisation
> integer :: size, ierr, status(MPI_STATUS_SIZE)
> CALL MPI_INIT(ierr)
> CALL MPI_COMM_RANK( MPI_COMM_WORLD, me, ierr ) CALL MPI_COMM_SIZE(
> MPI_COMM_WORLD, size, ierr ) end subroutine
> subroutine array_initialisation
> integer :: x,y,z,k
> allocate(occupancy(NX,NY,NZ))
> k = 0
> do x = 1,NX
>      do y = 1,NY
> 		do z = 1,NZ
> 	        k = k+1
>              occupancy(x,y,z)%cdata = k
> 		enddo
>      enddo
> enddo
> end subroutine
> end module
> PROGRAM simple
> use mpitest
> integer :: ierr
> call mpi_initialisation
> call array_initialisation
> call MPI_BARRIER ( MPI_COMM_WORLD, ierr )
> !deallocate(occupancy)
> write(*,*) 'MPI_FINALIZE: ',me
> CALL MPI_FINALIZE(ierr)
> END
> Pavan Balaji wrote:
>> Do you have a very simple (as simple as possible) program that
>> demonstrates this? Also, can you give some more information about
>> your installation --
>> 1. Which version of MPICH2 are you using?
>> 2. What configuration options were passed to MPICH2 during
>> configuration
>> 3. What process manager are you using?
>> 4. What command line did you use to launch the process manager?
>> 5. What command line did you use to launch the program?
>> 6. Anything other information we should probably know about in your
>> cluster, e.g., what OS, is there a firewall between the nodes, etc.
>>  -- Pavan
>> On 04/09/2008 09:49 PM, Gib Bogle wrote:
>>> My mpich-2 program seems to run correctly, but when it tries to
>>> execute MPI_Finalize() it gives a range of error messages, all
>>> apparently related to closing the socket connections.  Typical
>>> messages are:
>>> unable to read the cmd header on the pmi context, socket connection
>>> closed
>>> shutdown failed, sock ####, error 10093
>>> closesocket failed, sock ####, error 10093
>>> So far I haven't seen any bad consequences from these errors, but
>>> they are disconcerting.  Should I care?  Is there something I can do?
>>> Gib
This message was sent using IMP, the Internet Messaging Program.
