[mpich-discuss] Multi-homed system - specify "-ifhn" in machinefile
Jayesh Krishna
jayesh at mcs.anl.gov
Tue Apr 8 10:08:22 CDT 2008
Great... Let us know if you need any further help.
(PS: You can find a lot of information related to working with MPICH2 on
windows in the window's developer's guide - available at
http://www.mcs.anl.gov/research/projects/mpich2/documentation/index.php?s=do
cs)
Jayesh
_____
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Denis Lima
Sent: Monday, April 07, 2008 4:57 PM
Subject: Re: [mpich-discuss] Multi-homed system - specify "-ifhn" in
machinefile
Hello,
Thanks for your quick reply, but today I solved this issue by setting
the environment variable MPICH INTERFACE HOSTNAME with the local network
interface ip address.
Denis
----- Original Message -----
From: Jayesh <mailto:jayesh at mcs.anl.gov> Krishna
To: 'Denis Lima' <mailto:denisvl at uol.com.br>
Cc: mpich-discuss at mcs.anl.gov
Sent: Monday, April 07, 2008 11:48 AM
Subject: RE: [mpich-discuss] Multi-homed system - specify "-ifhn" in
machinefile
You can use the "-ifhn" option in the machinefile for specify the interface
to be used for MPI communication.
Let us know if it works for you.
(Note: In the machinefile specify, HOSTNAME:<NUM_OF_PROCS> -ifhn
<INTERFACE_IP_ADDR>. Now launch your MPI job with mpiexec using the
"-machinefile" option)
Jayesh
_____
Sent: Sunday, April 06, 2008 12:14 PM
Subject: [mpich-discuss] Multi-homed system
Hello,
I have an application running on 5 computers under Windows Xp, they all
belong to two distinct networks. One local (A) with only these computers,
and the other one for file sharing (B) with other pcs. It doesn't matter if
I specify the local ip (A) on the mpiexec -host argument the data exchange
always happens on network B. In the user's guide it says to use the
argument --ifhn=<ip address> on the mpd. Does the smpd service accept this
argument? Just configuring smpd with this argument in all computers enough
to be able to run on network A?
Sorry about the english,
Denis
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080408/7dccf9d3/attachment.htm>
