[MPICH] ROMIO. Two-phased run-time error
Rajeev Thakur
thakur at mcs.anl.gov
Wed Sep 19 13:59:54 CDT 2007
There is a bug in ROMIO that causes a seg fault for the particular set of
I/O hints used in BTIO. BTIO sets the collective buffering hints cb_nodes to
4 and cb_buffer_size to 1000000. If you do not set these hints and pass
MPI_INFO_NULL instead, it works. This can be done by adding the line
collbuf_nodes = 0
on line 29 in NPB3.2.1/NPB3.2-MPI/BT/full_mpiio.f
(just above the if statement)
Rajeev
> -----Original Message-----
> From: owner-mpich-discuss at mcs.anl.gov
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of
> Francisco Javier García Blas
> Sent: Wednesday, September 19, 2007 6:31 AM
> To: mpich-discuss at mcs.anl.gov
> Subject: [MPICH] ROMIO. Two-phased run-time error
> Hi all,
> We did some measurements with BTIO over PVFS and PVFS2 on lonestar at
> TACC (http://www.tacc.utexas.edu/services/userguides/lonestar/).
> We launched BTIO with 4 proccess and but when we launch BTIO
> with 9 or
> more proceess the bench fail. We tried to run BTIO with PVFS,
> PVFS2 and
> unix file system but it falied too.
> Debuging the error seems to be in collective writes.
> Two-phased does not
> invoke file primitives.
> We use mpich2-1.0.5p4 and compile it with gcc version 3.4.6.
> Any clue why this happens?
> Thanks a lot
> Computer Architecture, Communications and Systems Area.
> Computer Science Department. UNIVERSIDAD CARLOS III DE MADRID
> Avda. de la Universidad, 30
> 28911 Leganés (Madrid), SPAIN
> e-mail: fjblas at arcos.inf.uc3m.es
> fjblas at inf.uc3m.es
> Phone:(+34) 916249104
> FAX: (+34) 916249129
