[MPICH] MPICH105 shm drops packages on SUN niagara
chong tan chong_guan_tan at yahoo.com
Mon Sep 17 12:07:50 CDT 2007
In the 'change liost' of the new 106 release, I see thie item:
Bugfix for shm and ssm channels. Added missing read and write memory barriers for x86, and missing volatile in packet structure
  does it means this problem is fixed ?
  thanks
William Gropp <gropp at mcs.anl.gov> wrote:
  We're looking at it; I've added a variation of this to our regular tests.  No solution yet, however.  My guess is that there is a missing volatile or memory barrier somewhere; this should force us to clean up the current code.
  Bill
    On May 16, 2007, at 12:18 PM, chong tan wrote:
      No taker on this ?  There is an identical proble on Linux.  Just that I am not sure if this code can reproduce the problem.
  tan
  ----- Original Message ----
Sent: Friday, April 27, 2007 3:24:09 PM
Subject: Re: [MPICH] MPICH105 shm drops packages on SUN niagara
    The following code reproduces the problem.  I think you maybe able to reproduce the error on
  Linux, but I am not sure.
  It is best to run :
  mpiexec -n 8 a.out
  to reproduce the problem.  You will need a machine with 8CPU/cores.  SOmetime you will need to
  run the code multiple time to see the error.
  there will be files fast_mpi_?.dmp created, where ? is the rank of the related 'rank'.  When MPI get stuck,
  you should look at the last line of fast_mpi_0.dmp.  If it says:
  read from child 7
  then you should look at the last line of fast_mpi_7.dmp, it will say:
    read from master
  hope this help to debug the error.
  thanks
  tan
  #include "stdlib.h"
#include "stdio.h"
#include "mpi.h"
  #define LOOP_COUNT  1000000
#define DATA_SIZE   4
#define MP_TAG      999
  main()
    int     nProc, rank ;
    int     argc = 0 ;
    int     i, j, status ;
    char    buf[ 128 ] ;
    FILE    *pf ;
      MPI_Init( &argc, NULL ) ;
    MPI_Comm_size( MPI_COMM_WORLD, &nProc ) ;
    MPI_Comm_rank( MPI_COMM_WORLD, &rank ) ;
    sprintf( buf, "fast_mpi_%d.dmp", rank ) ;
    pf = fopen( buf, "w" ) ;
      if( !rank ) {
       int      **psend ;
       int      **precv ;
         psend = (int**)calloc( nProc, sizeof( int *) ) ;
       precv = (int**)calloc( nProc, sizeof( int *) ) ;
       for( i = 0 ; i < nProc ; i++ ) {
           psend[ i ] = (int*)calloc( DATA_SIZE, sizeof( int ) ) ;
           precv[ i ] = (int*)calloc( DATA_SIZE, sizeof( int ) ) ;
       for( i = 0 ; i < LOOP_COUNT ; i++ ) {
          fprintf( pf, "Master : loop %d\n", i ) ;
          fflush( pf ) ;
          for( j = 1 ; j < nProc ; j++ ) {
             fprintf( pf, "  read from child %d\n", j ) ;
             fflush( pf ) ;
             status = MPI_Recv( precv[ j ], DATA_SIZE, MPI_LONG, j, MP_TAG, MPI_COMM_WORLD, MP
I_STATUS_IGNORE ) ;
             fprintf( pf, "  read from child %d done, status = %d\n", j, status ) ;
             fflush( pf ) ;
             fprintf( pf, "  send to child %d\n", j ) ;
             fflush( pf ) ;
             status = MPI_Send( psend[ j ], DATA_SIZE - 1, MPI_LONG, j, MP_TAG, MPI_COMM_WORLD
             fprintf( pf, "  send to child %d done, status = %d\n", j, status ) ;
             fflush( pf ) ;
    } else {
       int  *psend ;
       int  *precv ;
         psend = (int*)calloc( DATA_SIZE, sizeof( int ) ) ;
       precv = (int*)calloc( DATA_SIZE, sizeof( int ) ) ;
             fprintf( pf, "  send to master\n" ) ;
             fflush( pf ) ;
             status = MPI_Send( psend, DATA_SIZE - 1, MPI_LONG, 0, MP_TAG, MPI_COMM_WORLD ) ;
             fprintf( pf, "  send to master done, status = %d\n", status ) ;
             fflush( pf ) ;
             fprintf( pf, "  read from master\n" ) ;
             fflush( pf ) ;
             status = MPI_Recv( precv, DATA_SIZE, MPI_LONG, 0, MP_TAG, MPI_COMM_WORLD, MPI_STATUS_IGNORE ) ;
             fprintf( pf, "  read from master done, status = %d\n", status ) ;
             fflush( pf ) ;
    fclose( pf ) ;
    MPI_Finalize() ;
  Ahhh...imagining that irresistible "new car" smell?
Check out new cars at Yahoo! Autos.
  Be a better Heartthrob. Get better relationship answers from someone who knows.
Yahoo! Answers - Check it out.
Luggage? GPS? Comic books?
Check out fitting  gifts for grads at Yahoo! Search.
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20070917/a5a583ae/attachment.htm>
