[MPICH] MPICH2 and Pascal
    Lykle Voort
    lyklevoort at gmail.com
    Sun Oct 21 14:41:37 CDT 2007
My experience with Pascal goes back to turbo pascal version 7, I am afraid,
but I have quite a bit of experience with calling c routines from fortran on
windows and linux.
The trick is to call a the mpi-routines, written in C, from Pascal. The
difficulty is usually to get the arguments and the function names right; the
linker takes care of the rest.
Are you developing for Windows or Linux? Which Pacal compiler do you use?
Lykle Voort
On 10/21/07, Lourival Mendes <mendes.lourival at gmail.com> wrote:
>    Hy everybody, as probably you saw before, I'm trying to use the MPICH2
> on the Pascal environment. I try to find something on the net but with
> almost no success.
>    Does anybody has an advice from where I should start?? Should I convert
> the headers and lib files from the standard installation or should I use the
> source code?? What is the best way?? How it works for the fortran code??
> Thanks in advance..
> Lourival J. Mendes Neto
Lykle Voort
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20071021/2594ef65/attachment.htm>
