[MPICH] MPICH2 and Pascal
    Lourival Mendes
    mendes.lourival at gmail.com
    Sun Oct 21 14:12:18 CDT 2007
Thanks Chan,
   I will take a look on it, because there is only the wiki you send but I
don't see  what is the file that contains the binding to be download and use
it with the Free Pascal Compiler... I will try get in contact with the FPC
discussion list...
   I asked for the Fortran because probably should be the same way that the
Pascal did to tranlate it
I will let you know soon...
Thanks
Lourival
2007/10/21, Anthony Chan <chan at mcs.anl.gov>:
> On Sun, 21 Oct 2007, Lourival Mendes wrote:
> >   Hy everybody, as probably you saw before, I'm trying to use the MPICH2
> on
> > the Pascal environment. I try to find something on the net but with
> almost
> > no success.
> >   Does anybody has an advice from where I should start?? Should I
> convert
> > the headers and lib files from the standard installation or should I use
> the
> > source code?? What is the best way??
> Found this link which might be interesting to you:
> http://wiki.freepascal.org/MPICH
> > How it works for the fortran code??
> MPICH2 should work nicely with most popular fortran compilers.
> A.Chan
Lourival J. Mendes Neto
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20071021/83c5345b/attachment.htm>
