[MPICH] Running on root's MPD as either root or another user
Matthew Chambers
matthew.chambers at vanderbilt.edu
Mon Oct 1 15:03:47 CDT 2007
Hi all,
The install guide seems unclear about how to do this or if it's even
possible. I have my user's .mpd.conf as:
MPD_SECRETWORD=foo
MPD_USE_ROOT_MPD=1
And my /etc/mpd.conf is:
MPD_SECRETWORD=foo
Permissions on the user's conf are: -rwx------
When permissions on the /etc/mpd.conf are: -rwx------
I can run mpdtrace and MPI jobs as root just fine, but when I try either
of those as the user, I get "open failed for root's mpd conf
filempdtrace: mpd_uncaught_except_tb handling"
So when I set permissions on the /etc/mpd.conf are: -rwx---r--
I can run mpdtrace as the user, but when I try to run an MPI job (e.g.
mpiexec -n 16 hostname ; not an MPI program, but still works fine with
MPICH2), it hangs. When I break it with CTRL-C I get the message
"(mpiexec 413): mpiexec: failed to obtain sock from manager". I can't
run mpdtrace or MPI jobs as root because of: "configuration file
/etc/mpd.conf is accessible by others \ change permissions to allow read
and write access only by you". This seems a bit of a catch-22.
I'm mostly interested in getting it working for the user. I don't have
the MPD binaries installed in the standard location, so I'm not sure how
to set the permissions. I tried setting everything to: -rwxr-sr-x
But that has the same error. The user only has an account on the head
node, is that the problem?
Matt Chambers
