[MPICH] clog2 problem when using MPI_Init_thread
    Anthony Chan
    chan at mcs.anl.gov
    Fri Nov 23 08:29:37 CST 2007
On Fri, 23 Nov 2007, Christoph Lupprich wrote:
> Hi there,
> I'm currently developing an MPI application, which runs quite fine.
> Problems is that for performance analysis I want to create clog2 logs.
> My application is multi-threaded and the logging mechanism crashes
> when I use MPI_Init_thread (which I need because that's what tells the
> logging component to split a process into multiple threads for
> displaying).
MPE logging does support multi-threaded application in the recent release.
What version of MPE2 you are using ?  Did you use user-defined logging
in your code ?
A.Chan
> Does anybody know if there's a know issue with the combination of
> logging and MPI_Init_thread or is it just my fault?
> Thanks and kind regards,
> Christoph
> Christoph Lupprich
> University of Applied Sciences Wiener Neustadt, Austria
