[MPICH] Error handling issue
AGPX
agpxnet at yahoo.it
Wed Nov 14 10:47:53 CST 2007
thanks for the reply. I think that only at the user code
level one can actuate a recovery strategy. In my scenario, I (wish)
simply delegate the computation of the failed evaluator to another one.
Main process must be aware of this and so it must be the handler of
that error. In my opinion, SMPD shouldn't abort all the process if one
fail. Any eventual MPI command (Send/Recv asynchronous/pending or not)
must fail when the relative process is died. That is: if the process 0
wait for a response from process 1 (through a Recv), if the process 1
die, the Recv must fail returing an error code. If the process 0 abort,
then all the job abort too.
Best regards,
Gianluca Arcidiacono
----- Messaggio originale -----
Da: Jayesh Krishna <jayesh at mcs.anl.gov>
A: AGPX <agpxnet at yahoo.it>
Cc: mpich-discuss at mcs.anl.gov
Inviato: Mercoledì 14 novembre 2007, 17:01:59
Oggetto: RE: [MPICH] Error handling issue
DIV {
MARGIN:0px;}
KIlling an MPI process results in the process manager
aborting all the MPI processes associated with the current job. This error is
not an MPI error (The errhandler associated with a communicator can only handle
MPI errors). The error message is then printed by the process manager (SMPD in
the case of windows).
I believe what you need is an MPI library
implementation where you could kill one of the MPI processes and still have the
MPI job running (the remaining MPI processes running). You could modify the
source code of SMPD to do that.
(PS: Strictly speaking this level of fault tolerance should
be handled, if possible, at the process manager/library level -- not in the user
code.)
Jayesh
Sent: Wednesday, November 14, 2007 7:39 AM
To: Jayesh
Krishna
Subject: Re: [MPICH]
I abort the
process by killing the process (from Task Manager). Basically, my application
(on the so called 'main machine', ID = 0) distribute his calculation on various
machines (called the 'evaluators'). When an evaluator abort for any reason
(could be also a blackout) I need to handle this situation in order to delegate
his calculation to another evaluator, so that I can avoid to lost calculations
already done by the other evaluators. Actually, when an evaluator abort (I have
tried to kill the process), the main process (ID = 0) abort with the error
message described and this is a serious problem for me.
Best
regards,
Gianluca
Arcidiacono
A:
Inviato:
Lunedì 12 novembre 2007, 17:29:52
issue
DIV {
MARGIN:0px;}
This could probably be an error message given by
the process manager.
How are you aborting the
process?
Jayesh
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of
AGPX
Sent: Sunday, November 11, 2007 6:37 AM
To:
Subject: [MPICH] Error handling
issue
I have write the following code wishing to avoid my main process
to abort on an MPI error:
MPI_Init(&argc,
&argv);
MPI_Comm_rank(MPI_COMM_WORLD,
&MPIId);
MPI_Comm_size(MPI_COMM_WORLD,
&numprocs);
MPI_Comm_set_errhandler(MPI_COMM_WORLD,
MPI_ERRORS_RETURN);
but
when I try to terminate a job process on another machine (pcamd3000 is the main
machine, pcamd2600 the other. I use Windows XP Pro on both), then the main
process abort. Here the error message:
job
aborted:
rank:
node: exit code[: error message]
0:
pcamd3000: 1: Fatal error in MPI_Send: Other MPI error, error stack:
MPI_Send(173).............................:
MPI_Send(buf=00B458B0, count=1, MPI_
INT,
dest=1, tag=0, comm=0x84000000) failed
MPIDI_CH3I_Progress(148)..................:
handle_sock_op failed
MPIDI_CH3I_Progress_handle_sock_event(497):
MPIDU_Sock_wait(2603).....................:
Il nome di rete specificato non è più
disponibile. (errno 64)
1:
pcamd2600: 1: process 1 exited without calling finalize
2:
pcamd2600: 1
(note
that the message: 'Il
disponibile.' in english is: 'The network name specified is no more
available'.)
What I miss? I have more than one communicator, but I have
used MPI_Comm_set_errhandler as well to set their error handler to
MPI_ERRORS_RETURN. The code is:
MPI_Group_incl(worldGroup,
nRanks, ranks, &handle.group);
MPI_Comm_create(MPI_COMM_WORLD,
handle.group, &handle.comm);
MPI_Comm_set_errhandler(handle.comm,
MPI_ERRORS_RETURN);
I
have also tried with MPI_Errhandler_set, but this doesn't help:
MPI_Errhandler_set(...,
MPI_ERRORS_RETURN);
Any suggestion?
AGPX
L'email della prossima generazione? Puoi averla con la
nuova Yahoo!
Mail
nuova
Yahoo! Mail
___________________________________
L'email della prossima generazione? Puoi averla con la nuova Yahoo! Mail: http://it.docs.yahoo.com/nowyoucan.html
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20071114/4abb1f3c/attachment.htm>
