[MPICH] debug flag
Rajeev Thakur
thakur at mcs.anl.gov
Tue May 29 13:10:09 CDT 2007
Can you try disabling aggregation and see if the error still remains. You
can disable it by creating an info object as follows and passing it to
File_set_view
MPI_Info_set(info, "cb_config_list", "*:*");
Rajeev
> -----Original Message-----
> From: owner-mpich-discuss at mcs.anl.gov
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Wei-keng Liao
> Sent: Tuesday, May 29, 2007 1:33 AM
> To: Howard Pritchard
> Cc: mpich-discuss at mcs.anl.gov
> Subject: Re: [MPICH] debug flag
> Howard,
> Thanks for this information. It is very helpful. I was able
> to find more
> details by using the debug built mpich. Below is what I found
> from the
> coredump that may help debugging the ROMIO source.
> 1. coredump is from MPI rank 2919. I allocated 4000 MPI processes,
> (2000 nodes, each nodes has 2 CPUs). I am checking
> mpich2-1.0.2 source.
> 2. MPI_Abort() is called at line 97 by function
> ADIOI_Calc_aggregator(),
> in file ad_aggregate.c where
> rank_index = 5335, fd->hints->cb_nodes = 2000, off = 2802007600,
> min_off = 0, fd_size = 525164 (fd_size should be 11000000))
> 3. It is function ADIOI_Calc_my_req() called
> ADIOI_Calc_aggregator() at
> line 240, from file ad_aggregate.c, where
> i = 0 in loop for (i=0; i < contig_access_count; i++)
> off = 2802007600, min_st_offset = 0, fd_len = 400,
> fd_size = 525164
> 4. It is function ADIOI_GEN_WriteStridedColl() called
> ADIOI_Calc_my_req()
> at line 170, from file ad_write_coll.c
> I would like to see what went wrong with fd_size from function
> ADIOI_Calc_file_domains() where fd_size is set and saw
> that fd_size is
> determined by st_offsets[] and end_offsets[] which depend
> on variables
> start_offset and end_offset.
> So, I went a few line up and checked the values for variables
> start_offset and end_offset. They were set by
> ADIOI_Calc_my_off_len()
> at line 101 and I found the value of end_offset must be wrong!
> end_offset should always >= start_offset, but the core shows that
> start_offset = 2802007600, end_offset = 244727039
> So, I looked into ADIOI_Calc_my_off_len() in
> ad_read_coll.c and checked
> variable end_offset_ptr which was set by variable
> end_offset at line
> 453, since filetype_size > 0 and filetype_is_contig == 0.
> Hence, the only place end_offset is set is at line 420:
> end_offset = off + frd_size - 1;
> end_offset is determined by off and frd_size. However, frd_size
> is declared as an integer. But end_offset is ADIO_Offset. Maybe
> it is an type overflow! At line 351, I can see a type cast
> frd_size = (int) (disp + flat_file->indices[i] + ...
> Something fishy here. Unfortunately, the coredump does
> not cover here.
> Look like an interactive debugging with a break point
> cannot be avoided.
> Wei-keng
> On Mon, 28 May 2007, Howard Pritchard wrote:
> > Hello Wei-keng,
> > Here is a way on xt/qk systems to compile with the debug
> mpich2 library:
> > 1) do
> > module show xt-mpt
> > to see which mpich2 the system manager has made the default.
> > For instance, on an internal system here at cray this
> command shows:
> > /opt/modulefiles/xt-mpt/1.5.49:
> > setenv MPT_DIR /opt/xt-mpt/1.5.49
> > setenv MPICHBASEDIR /opt/xt-mpt/1.5.49/mpich2-64
> > setenv MPICH_DIR /opt/xt-mpt/1.5.49/mpich2-64/P2
> > setenv MPICH_DIR_FTN_DEFAULT64
> /opt/xt-mpt/1.5.49/mpich2-64/P2W
> > prepend-path LD_LIBRARY_PATH /opt/xt-mpt/1.5.49/mpich2-64/P2/lib
> > prepend-path PATH /opt/xt-mpt/1.5.49/mpich2-64/P2/bin
> > prepend-path MANPATH /opt/xt-mpt/1.5.49/mpich2-64/man
> > prepend-path MANPATH /opt/xt-mpt/1.5.49/romio/man
> > prepend-path PE_PRODUCT_LIST MPT
> > The debug library you want to use is thus going to be
> picked up by the
> > mpicc installed at:
> > /opt/xt-mpt/1.5.49/mpich2-64/P2DB
> > 2) Now with the cray compiler scripts like cc, ftn, etc.
> you specify the
> > alternate location to use for compiling/linking by
> > cc -driverpath=/opt/xt-mpt/1.5.49/mpich2-64/P2DB/bin -o
> a.out.debug ......
> > or whichever path is appropriate for the xt-mpt installed
> on your system.
> > 3) When you rerun the binary, you may want to set the MPICH_DBMASK
> > environment variable to 0x200.
> > I am pretty sure you are running out of memory, based on the area in
> > the ADIO_Calc_my_req where the error arises. Clearly this
> is not a very
> > good way to report an oom condition. I'll investigate.
> > You may be able to save some memory by tweaking the environment
> > variables controlling mpi buffer space. Refer to the
> intro_mpi man page
> > on your xt/qk system.
> > Hope this helps,
> > Howard
> > Wei-keng Liao wrote:
> >> Well, I am aware of mpich2version, but unforturnately that
> command is not
> >> available to users on that machine. The only commands
> avaliable to me are
> >> mpicc, mpif77, mpif90, and mpicxx.
> >> Wei-keng
> >> On Fri, 25 May 2007, Anthony Chan wrote:
> >>> <mpich2-install-dir>/bin/mpich2version may show if
> --enable-g is set.
> >>> A.Chan
> >>> On Fri, 25 May 2007, Wei-keng Liao wrote:
> >>>> The problem is that I cannot run my own mpich on the
> machine. I can see
> >>>> the MPICH I am using is of version 2-1.0.2 from peeking
> at mpif90 script.
> >>>> Is there a way to know if it is built using
> --enable-g=dbg option from
> >>>> the
> >>>> mpif90 script?
> >>>> I don't know if this help, but below is the whole error message:
> >>>> aborting job:
> >>>> application called MPI_Abort(MPI_COMM_WORLD, 1) - process <id>
> >>>> (there are 4000 lines, each with a distinct id number)
> >>>> ----- DEBUG: PCB, CONTEXT, STACK TRACE ---------------------
> >>>> PROCESSOR [ 0]
> >>>> log_nid = 15 phys_nid = 0x98 host_id = 7691
> host_pid = 18545
> >>>> group_id = 12003 num_procs = 4000 rank = 15
> local_pid = 3
> >>>> base_node_index = 0 last_node_index = 1999
> >>>> text_base = 0x00000000200000 text_len = 0x00000000400000
> >>>> data_base = 0x00000000600000 data_len = 0x00000000a00000
> >>>> stack_base = 0x000000fec00000 stack_len = 0x00000001000000
> >>>> heap_base = 0x00000001200000 heap_len = 0x0000007b000000
> >>>> ss = 0x000000000000001f fs = 000000000000000000 gs =
> >>>> 0x0000000000000017
> >>>> rip = 0x00000000002d46fe
> >>>> rdi = 0x0000000006133a90 rsi = 0xffffffffdc0003c2 rbp =
> >>>> 0x00000000ffbf9d40
> >>>> rsp = 0x00000000ffbf9cc0 rbx = 0x0000000000000190 rdx =
> >>>> 0x000000003eb08c39
> >>>> rcx = 0x0000000008ea18b0 rax = 0x0000000008ecff30 cs =
> >>>> 0x000000000000001f
> >>>> R8 = 0x0000000007ad2ab0 R9 = 0xfffffffffffffe0c R10 =
> >>>> 0x0000000008e6bd30
> >>>> R11 = 0x0000000000000262 R12 = 0x0000000000000a8c R13 =
> >>>> 0xfffffffff0538770
> >>>> R14 = 0x00000000fffffe0c R15 = 0x0000000008ed3dc0
> >>>> rflg = 0x0000000000010206 prev_sp = 0x00000000ffbf9cc0
> >>>> error_code = 6
> >>>> SIGNAL #[11][Segmentation fault] fault_address =
> 0xffffffff78ed4cc8
> >>>> 0xffbf9cc0 0x ffbf9cf0 0x fa0 0x
> a00006b6c 0x
> >>>> a8c3e9ab7ff
> >>>> 0xffbf9ce0 0x 8ed7c50 0x 7d0 0x
> 0 0x
> >>>> 6b6c002d455b
> >>>> 0xffbf9d00 0x 8ea18b0 0x 8e6bd30 0x
> 61338a0 0x
> >>>> fa0
> >>>> 0xffbf9d20 0x 0 0x 61338a0 0x
> 8036c 0x
> >>>> 8ec4390
> >>>> 0xffbf9d40 0x ffbf9e80 0x 2d2280 0x
> 8ecff30 0x
> >>>> 8036c
> >>>> 0xffbf9d60 0x fa0 0x ffbf9de4 0x
> ffbf9de8 0x
> >>>> ffbf9df0
> >>>> 0xffbf9d80 0x ffbf9df8 0x 0 0x
> 0 0x
> >>>> 8ebc680
> >>>> 0xffbf9da0 0x 1770 0x 7d000a39f88 0x
> 0 0x
> >>>> 650048174f
> >>>> 0xffbf9dc0 0x 14fb184c000829 0x 6a93500 0x
> ffbf9e30 0x
> >>>> 292e54
> >>>> 0xffbf9de0 0x 0 0x 8ed3dc0 0x
> 7af 0x
> >>>> 0
> >>>> 0xffbf9e00 0x 0 0x 8ecc0a0 0x
> 8ecff30 0x
> >>>> 8036c
> >>>> 0xffbf9e20 0x 100000014 0x 8e6bd30 0x
> 8ea18b0 0x
> >>>> 1770
> >>>> 0xffbf9e40 0xffffffff6793163f 0x 6b6c00a39fa8 0x
> fa00000000f 0x
> >>>> 61338a0
> >>>> 0xffbf9e60 0x 4c000829 0x 14fb18 0x
> 65 0x
> >>>> 0
> >>>> 0xffbf9e80 0x ffbf9ee0 0x 2a397c 0x
> 866b60 0x
> >>>> ffbf9eb0
> >>>> Stack Trace: ------------------------------
> >>>> #0 0x00000000002d46fe in ADIOI_Calc_my_req()
> >>>> #1 0x00000000002d2280 in ADIOI_GEN_WriteStridedColl()
> >>>> #2 0x00000000002a397c in MPIOI_File_write_all()
> >>>> #3 0x00000000002a3a4a in PMPI_File_write_all()
> >>>> #4 0x00000000002913a8 in pmpi_file_write_all_()
> >>>> could not find symbol for addr 0x73696e6966204f49
> >>>> On Fri, 25 May 2007, Robert Latham wrote:
> >>>>> On Fri, May 25, 2007 at 03:56:16PM -0500, Wei-keng Liao wrote:
> >>>>>> I have an MPI I/O application that runs fine up to
> 1000 processes, but
> >>>>>> failed when using 4000 processes. Parts of error message are
> >>>>>> aborting job:
> process 1456
> >>>>>> My question is what debug flags should I use for
> compiling and running
> >>>>>> in
> >>>>>> order to help find what exact location in function
> ADIOI_Calc_my_req()
> >>>>>> causes this error?
> >>>>> Hi Wei-keng
> >>>>> If you build MPICH2 with --enable-g=dbg, then all of
> MPI will be built
> >>>>> with debugging symbols. Be sure to 'make clean'
> first: the ROMIO
> >>>>> objects might not rebuild otherwise.
> >>>>> I wonder what caused the abort? maybe ADIOI_Malloc
> failed to allocate
> >>>>> memory? Well, a stack trace with debugging symbols should be
> >>>>> interesting.
> >>>>> ==rob
> >>>>> Rob Latham
> >>>>> Mathematics and Computer Science Division A215 0178
> EA2D B059 8CDF
> >>>>> Argonne National Lab, IL USA B29D F333
> 664A 4280 315B
