[MPICH] debug flag
Wei-keng Liao
wkliao at ece.northwestern.edu
Tue May 29 01:32:55 CDT 2007
Howard,
Thanks for this information. It is very helpful. I was able to find more
details by using the debug built mpich. Below is what I found from the
coredump that may help debugging the ROMIO source.
1. coredump is from MPI rank 2919. I allocated 4000 MPI processes,
(2000 nodes, each nodes has 2 CPUs). I am checking mpich2-1.0.2 source.
2. MPI_Abort() is called at line 97 by function ADIOI_Calc_aggregator(),
in file ad_aggregate.c where
rank_index = 5335, fd->hints->cb_nodes = 2000, off = 2802007600,
min_off = 0, fd_size = 525164 (fd_size should be 11000000))
3. It is function ADIOI_Calc_my_req() called ADIOI_Calc_aggregator() at
line 240, from file ad_aggregate.c, where
i = 0 in loop for (i=0; i < contig_access_count; i++)
off = 2802007600, min_st_offset = 0, fd_len = 400, fd_size = 525164
4. It is function ADIOI_GEN_WriteStridedColl() called ADIOI_Calc_my_req()
at line 170, from file ad_write_coll.c
I would like to see what went wrong with fd_size from function
ADIOI_Calc_file_domains() where fd_size is set and saw that fd_size is
determined by st_offsets[] and end_offsets[] which depend on variables
start_offset and end_offset.
So, I went a few line up and checked the values for variables
start_offset and end_offset. They were set by ADIOI_Calc_my_off_len()
at line 101 and I found the value of end_offset must be wrong!
end_offset should always >= start_offset, but the core shows that
start_offset = 2802007600, end_offset = 244727039
So, I looked into ADIOI_Calc_my_off_len() in ad_read_coll.c and checked
variable end_offset_ptr which was set by variable end_offset at line
453, since filetype_size > 0 and filetype_is_contig == 0.
Hence, the only place end_offset is set is at line 420:
end_offset = off + frd_size - 1;
end_offset is determined by off and frd_size. However, frd_size
is declared as an integer. But end_offset is ADIO_Offset. Maybe
it is an type overflow! At line 351, I can see a type cast
frd_size = (int) (disp + flat_file->indices[i] + ...
Something fishy here. Unfortunately, the coredump does not cover here.
Look like an interactive debugging with a break point cannot be avoided.
Wei-keng
On Mon, 28 May 2007, Howard Pritchard wrote:
> Hello Wei-keng,
> Here is a way on xt/qk systems to compile with the debug mpich2 library:
> 1) do
> module show xt-mpt
> to see which mpich2 the system manager has made the default.
> For instance, on an internal system here at cray this command shows:
> /opt/modulefiles/xt-mpt/1.5.49:
> setenv MPT_DIR /opt/xt-mpt/1.5.49
> setenv MPICHBASEDIR /opt/xt-mpt/1.5.49/mpich2-64
> setenv MPICH_DIR /opt/xt-mpt/1.5.49/mpich2-64/P2
> setenv MPICH_DIR_FTN_DEFAULT64 /opt/xt-mpt/1.5.49/mpich2-64/P2W
> prepend-path LD_LIBRARY_PATH /opt/xt-mpt/1.5.49/mpich2-64/P2/lib
> prepend-path PATH /opt/xt-mpt/1.5.49/mpich2-64/P2/bin
> prepend-path MANPATH /opt/xt-mpt/1.5.49/mpich2-64/man
> prepend-path MANPATH /opt/xt-mpt/1.5.49/romio/man
> prepend-path PE_PRODUCT_LIST MPT
> The debug library you want to use is thus going to be picked up by the
> mpicc installed at:
> /opt/xt-mpt/1.5.49/mpich2-64/P2DB
> 2) Now with the cray compiler scripts like cc, ftn, etc. you specify the
> alternate location to use for compiling/linking by
> cc -driverpath=/opt/xt-mpt/1.5.49/mpich2-64/P2DB/bin -o a.out.debug ......
> or whichever path is appropriate for the xt-mpt installed on your system.
> 3) When you rerun the binary, you may want to set the MPICH_DBMASK
> environment variable to 0x200.
> I am pretty sure you are running out of memory, based on the area in
> the ADIO_Calc_my_req where the error arises. Clearly this is not a very
> good way to report an oom condition. I'll investigate.
> You may be able to save some memory by tweaking the environment
> variables controlling mpi buffer space. Refer to the intro_mpi man page
> on your xt/qk system.
> Hope this helps,
> Howard
> Wei-keng Liao wrote:
>> Well, I am aware of mpich2version, but unforturnately that command is not
>> available to users on that machine. The only commands avaliable to me are
>> mpicc, mpif77, mpif90, and mpicxx.
>> Wei-keng
>> On Fri, 25 May 2007, Anthony Chan wrote:
>>> <mpich2-install-dir>/bin/mpich2version may show if --enable-g is set.
>>> A.Chan
>>> On Fri, 25 May 2007, Wei-keng Liao wrote:
>>>> The problem is that I cannot run my own mpich on the machine. I can see
>>>> the MPICH I am using is of version 2-1.0.2 from peeking at mpif90 script.
>>>> Is there a way to know if it is built using --enable-g=dbg option from
>>>> the
>>>> mpif90 script?
>>>> I don't know if this help, but below is the whole error message:
>>>> aborting job:
>>>> application called MPI_Abort(MPI_COMM_WORLD, 1) - process <id>
>>>> (there are 4000 lines, each with a distinct id number)
>>>> ----- DEBUG: PCB, CONTEXT, STACK TRACE ---------------------
>>>> PROCESSOR [ 0]
>>>> log_nid = 15 phys_nid = 0x98 host_id = 7691 host_pid = 18545
>>>> group_id = 12003 num_procs = 4000 rank = 15 local_pid = 3
>>>> base_node_index = 0 last_node_index = 1999
>>>> text_base = 0x00000000200000 text_len = 0x00000000400000
>>>> data_base = 0x00000000600000 data_len = 0x00000000a00000
>>>> stack_base = 0x000000fec00000 stack_len = 0x00000001000000
>>>> heap_base = 0x00000001200000 heap_len = 0x0000007b000000
>>>> ss = 0x000000000000001f fs = 000000000000000000 gs =
>>>> 0x0000000000000017
>>>> rip = 0x00000000002d46fe
>>>> rdi = 0x0000000006133a90 rsi = 0xffffffffdc0003c2 rbp =
>>>> 0x00000000ffbf9d40
>>>> rsp = 0x00000000ffbf9cc0 rbx = 0x0000000000000190 rdx =
>>>> 0x000000003eb08c39
>>>> rcx = 0x0000000008ea18b0 rax = 0x0000000008ecff30 cs =
>>>> 0x000000000000001f
>>>> R8 = 0x0000000007ad2ab0 R9 = 0xfffffffffffffe0c R10 =
>>>> 0x0000000008e6bd30
>>>> R11 = 0x0000000000000262 R12 = 0x0000000000000a8c R13 =
>>>> 0xfffffffff0538770
>>>> R14 = 0x00000000fffffe0c R15 = 0x0000000008ed3dc0
>>>> rflg = 0x0000000000010206 prev_sp = 0x00000000ffbf9cc0
>>>> error_code = 6
>>>> SIGNAL #[11][Segmentation fault] fault_address = 0xffffffff78ed4cc8
>>>> 0xffbf9cc0 0x ffbf9cf0 0x fa0 0x a00006b6c 0x
>>>> a8c3e9ab7ff
>>>> 0xffbf9ce0 0x 8ed7c50 0x 7d0 0x 0 0x
>>>> 6b6c002d455b
>>>> 0xffbf9d00 0x 8ea18b0 0x 8e6bd30 0x 61338a0 0x
>>>> fa0
>>>> 0xffbf9d20 0x 0 0x 61338a0 0x 8036c 0x
>>>> 8ec4390
>>>> 0xffbf9d40 0x ffbf9e80 0x 2d2280 0x 8ecff30 0x
>>>> 8036c
>>>> 0xffbf9d60 0x fa0 0x ffbf9de4 0x ffbf9de8 0x
>>>> ffbf9df0
>>>> 0xffbf9d80 0x ffbf9df8 0x 0 0x 0 0x
>>>> 8ebc680
>>>> 0xffbf9da0 0x 1770 0x 7d000a39f88 0x 0 0x
>>>> 650048174f
>>>> 0xffbf9dc0 0x 14fb184c000829 0x 6a93500 0x ffbf9e30 0x
>>>> 292e54
>>>> 0xffbf9de0 0x 0 0x 8ed3dc0 0x 7af 0x
>>>> 0
>>>> 0xffbf9e00 0x 0 0x 8ecc0a0 0x 8ecff30 0x
>>>> 8036c
>>>> 0xffbf9e20 0x 100000014 0x 8e6bd30 0x 8ea18b0 0x
>>>> 1770
>>>> 0xffbf9e40 0xffffffff6793163f 0x 6b6c00a39fa8 0x fa00000000f 0x
>>>> 61338a0
>>>> 0xffbf9e60 0x 4c000829 0x 14fb18 0x 65 0x
>>>> 0
>>>> 0xffbf9e80 0x ffbf9ee0 0x 2a397c 0x 866b60 0x
>>>> ffbf9eb0
>>>> Stack Trace: ------------------------------
>>>> #0 0x00000000002d46fe in ADIOI_Calc_my_req()
>>>> #1 0x00000000002d2280 in ADIOI_GEN_WriteStridedColl()
>>>> #2 0x00000000002a397c in MPIOI_File_write_all()
>>>> #3 0x00000000002a3a4a in PMPI_File_write_all()
>>>> #4 0x00000000002913a8 in pmpi_file_write_all_()
>>>> could not find symbol for addr 0x73696e6966204f49
>>>> On Fri, 25 May 2007, Robert Latham wrote:
>>>>> On Fri, May 25, 2007 at 03:56:16PM -0500, Wei-keng Liao wrote:
>>>>>> I have an MPI I/O application that runs fine up to 1000 processes, but
>>>>>> failed when using 4000 processes. Parts of error message are
>>>>>> aborting job:
>>>>>> application called MPI_Abort(MPI_COMM_WORLD, 1) - process 1456
>>>>>> My question is what debug flags should I use for compiling and running
>>>>>> in
>>>>>> order to help find what exact location in function ADIOI_Calc_my_req()
>>>>>> causes this error?
>>>>> Hi Wei-keng
>>>>> If you build MPICH2 with --enable-g=dbg, then all of MPI will be built
>>>>> with debugging symbols. Be sure to 'make clean' first: the ROMIO
>>>>> objects might not rebuild otherwise.
>>>>> I wonder what caused the abort? maybe ADIOI_Malloc failed to allocate
>>>>> memory? Well, a stack trace with debugging symbols should be
>>>>> interesting.
>>>>> ==rob
>>>>> Rob Latham
>>>>> Mathematics and Computer Science Division A215 0178 EA2D B059 8CDF
>>>>> Argonne National Lab, IL USA B29D F333 664A 4280 315B
