[MPICH] debug flag
Wei-keng Liao
wkliao at ece.northwestern.edu
Sun May 27 09:03:27 CDT 2007
I just tried your approach and got the error:
elf_check_version failed
yod: Unable to load program(s).
The file, /bin/hostname
is unrecognized executable type
I guess yod only recognizes executables that are compiled by MPI.
I also tried call MPI_Get_processor_name() in an MPI program. I got
nid00061 and nid00062 when I allocated 2 nodes. But they are not host
names for the 2 nodes. I also tried gethostname() right after
MPI_Get_processor_name() and it printed out a different name, yodjag16,
and always the same on each node.
Wei-keng
On Sun, 27 May 2007, Anthony Chan wrote:
> It is possible that the Cray has its own process manager that yod is only
> way to interact with the process manager and probably the only one knows
> the nodes allocated. If that is the case, you could try this in your PBS
> script.
>> cat <your_pbs_script>
> #!/bin/sh
> #PBS -l nodes=<num_of_nodes>
> YOD_NODEFILE=<my_node_file>
> rm -f ${YOD_NODEFILE}
> yod -size <num_of_nodes> hostname > ${YOD_NODEFILE}
> mpdboot -n <num_of_nodes> -f ${YOD_NODEFILE}
> mpiexec -n <num_of_nodes> a.out
> Not sure if this works, may worth a try.
> A.Chan
> On Sat, 26 May 2007, Wei-keng Liao wrote:
>> The machine is a Cray XT3, 4. The batch is PBS and the command to launch
>> an MPI job is "yod" as described in the user guide.
>> I tried to replace yod with mpich mpdboot and mpiexec, etc. I also used
>> the PBS environment variable PBS_NODEFILE in mpdboot, but the node file
>> does not contain the hostnames of nodes allocated by the PBS. It actually
>> always contains just one yod node, no matter how many nodes I request in
>> PBS script.
>> Any idea of how to do it?
>> Wei-keng
>> On Sat, 26 May 2007, Rajeev Thakur wrote:
>>> Are you sure you can't run your own MPICH2 on the machine? It is just a
>>> user-level library. Once the scheduler assigns you a set of nodes, you can
>>> run mpd and your own mpiexec.
>>> Rajeev
