[MPICH] debug flag
    Rajeev Thakur
    thakur at mcs.anl.gov
    Sat May 26 23:35:28 CDT 2007
If it's an XT-3/4 it's tough. If it were just a Linux cluster it would have
been possible.
Rajeev
> -----Original Message-----
> From: Wei-keng Liao [mailto:wkliao at ece.northwestern.edu]
> Sent: Saturday, May 26, 2007 9:48 PM
> To: Rajeev Thakur
> Cc: mpich-discuss at mcs.anl.gov
> Subject: Re: [MPICH] debug flag
> The machine is a Cray XT3, 4. The batch is PBS and the
> command to launch
> an MPI job is "yod" as described in the user guide.
> I tried to replace yod with mpich mpdboot and mpiexec, etc. I
> also used
> the PBS environment variable PBS_NODEFILE in mpdboot, but the
> node file
> does not contain the hostnames of nodes allocated by the PBS.
> It actually
> always contains just one yod node, no matter how many nodes I
> request in
> PBS script.
> Any idea of how to do it?
> Wei-keng
> On Sat, 26 May 2007, Rajeev Thakur wrote:
> > Are you sure you can't run your own MPICH2 on the machine?
> It is just a
> > user-level library. Once the scheduler assigns you a set of
> nodes, you can
> > run mpd and your own mpiexec.
> > Rajeev
