[MPICH] Can I use mpiexec to launch different command prompts for different ranks? - Read input from a file
Jayesh Krishna
jayesh at mcs.anl.gov
Thu May 24 09:06:49 CDT 2007
You can write a program to pop up a GUI which accepts the user's input.
Once the process manager is run manually (1. Stop the running process
manager -- "smpd -stop" 2. Run the process manager in a command window --
"smpd -d" 3. Repeat 1 & 2 for both the machines) the user will be able to
interact with the GUI on both the machines.
Another way to tackle your problem is to modify your program to read the
inputs from a file (the programs would execute on the different machines and
can access different files containing the different inputs)
Jayesh
-----Original Message-----
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Yu-Cheng Chou
Sent: Wednesday, May 23, 2007 11:10 AM
Subject: RE: [MPICH] Can I use mpiexec to launch different command prompts
for different ranks? - Try starting manually
These two programs are in two different Windows machines. Is there still a
way to bring up two command prompts on the host machine for user input?
Thanks!
> Hi,
> One way to do it is to set the PMI environment variables (see the
> "Debugging jobs by starting them manually" section in the window's
> developer's guide -- available at
> http://www-unix.mcs.anl.gov/mpi/mpich/)
> and executing the programs manually on two windows/command prompts.
> ###############2 proc job#########################
> 1) Start two command prompts -- run setmpi2.bat (see window's
> developer's
> guide) on the two windows as follows
> On 1st window -- setmpi2.bat 0 2
> On 2nd window -- setmpi2.bat 1 2
> 2) Run your program manually on each window (Note that you do not use
> mpiexec to launch the program -- all the info is provided by setmpi2.bat)
> On 1st window -- testprogram.exe
> On 2nd window -- testprogram.exe
> Let us know if this works for you.
