[MPICH] ch3:sctp configure broken
Brad Penoff
penoff at cs.ubc.ca
Wed May 23 10:53:45 CDT 2007
hey Steve,
I learned what I think you're problem is...
I had seen in the config.log that you sent me that it couldn't find your
libsctp. It used to be that all sctp_XXX() API calls were in a library
called libsctp for all platforms; this is still the case for most OS's.
In recent FreeBSD 7 implementations, I've been told that these API calls
have snuck into libc itself. On this end, we had explicitly built libsctp
previously, we so didn't see the problem building ch3:sctp. For you
however, no libsctp will be a problem because unfortunately, the configure
script in its current state requires libsctp to exist, and sctp_recvmsg to
be a part of it.
So for now, the suggested solution is to make some ficticious libsctp.a
somewhere and have it be a soft-link to your libc.a assuming that...
find / -name libc.a | xargs nm | grep sctp_
...returns something. Pass the location of your libsctp.a soft-link into
--with-sctp-lib (or just set the location yourself in your LDFLAGS) when
you run configure.
If...
...doesn't return anything, then we need to contact the FreeBSD 7
developers soon (I think the deadline for their final commit is
approaching soon).
On a semi-related note, can you let me know also if netinet/sctp.h exists
somewhere within your system's CPPFLAGS?
brad
On Wed, 23 May 2007, Brad Penoff wrote:
> hey Steve,
> I've tried to answer below in-line.
> brad
> On Tue, 22 May 2007, Steve Kargl wrote:
>> On Tue, May 22, 2007 at 06:53:16PM -0700, Brad Penoff wrote:
>>> I have been running mpich2-1.0.5p4 ch3:sctp on FreeBSD 6.1, 6.2, and 7.0
>>> very recently (EuroPVM/MPI deadline) so I'm surprised it's failing. I
>>> had
>>> a few questions about your setup...
>>> 1) Just curious, but do you have SCTP-capable kernels?
>> yes.
> So I'm assuming "options SCTP" is in the kernel config?
>>> 2) Which FreeBSD and which kernel are you using?
>> FreeBSD-7.0 built from source on Friday a few hours
>> before the gcc-4.2 import. Hardware is 7 nodes
>> that are all Tyan K8SR based amd64 systems. See
> I've sent an email to our FreeBSD colleagues so I'll get back to you on this.
> Just curious but where exactly do you obtain your source from?
>> http://troutmask.apl.washington.edu/~kargl/hpc.html
>> I just added node16, so some numbers at the URL don't
>> add up correct.
>>> 3) Do non-MPI/"normal" SCTP-based applications work?
>> Haven't tried any other sctp apps. Do you have a suggestion?
> I could give you some but first see #5 below...
>>> 4) What arguments did you supply to configure?
>> None of the following work
>> ./configure --with-device=ch3:sctp
>> ./configure --with-device=ch3:sctp --prefix=/usr/local/mpich2
>> --enable-fast
>> --enable-fast \
>> --enable-shared
>> --enable-fast \
>> --enable-shared --enable-static
>>> 5) Can you send me (off-list) your
>>> src/mpid/ch3/channels/sctp/config.log?
>> See follow up email.
> I saw your config.log and it can't seem to find libsctp.a or libsctp.so...
> can you do a find on a your system to see if these exist? The same can be
> said about your netinet/sctp.h; these locations need to be pasted into
> --with-sctp, --with-sctp-lib, and/or --with-sctp-include so that LDFLAGS and
> CPPFLAGS can be set appropriately (or you can set them yourself). Or if
> these files don't exist on your system, we have another problem...
>>> There is some help in the top-level README file; just search for
>>> ch3:sctp.
>>> There are some stack-specific instructions on how to compile (and if you
>>> followed them already, I don't mean to insult you).
>> Read it.
>> BTW, do you use bash?
> Generally, yes, and come to think of it, I have when building ch3:sctp almost
> exclusively.
> brad
>> Steve
