[MPICH] Using non-default ethernet interfaces
    Jeff Squyres
    jsquyres at cisco.com
    Thu May 17 09:21:59 CDT 2007
Thanks Ralph; that also worked (I used Anthony's solution before
reading yours).  Your solution allowed mpdboot to use my alternate
hostnames without barfing.
I had originally tried having a hostfile like this:
m1$ cat hostfile
m1-fast
m2-fast
m1$ mpdboot -n 2 -f hostfile
And got a weird error (see my prior e-mail).  Shouldn't mpdboot be
smart enough to be able to figure out that it is on the same host as
m1-fast, and not require the --ifhn argument on the command line?
Based on the behavior of prior versions of MPICH (and LAM/MPI), I had
expected that simply supplying the -fast hostnames in the hostfile a)
would allow mpdboot to work properly, and b) MPI apps started via the
mpd would "inherit" the -fast hostnames and use them for MPI pt2pt
communication.
This is somewhat of a moot point since your method works; I mention
it simply as a usability / Law of Least Astonishment issue.
(BTW, messages sent through this listserver seem to take quite a
while to be delivered; 30+ minutes sometimes...)
On May 16, 2007, at 6:29 PM, Ralph Butler wrote:
> This can be a bit tricky to get right no matter which way you try
> to do it, and there are
> multiple ways to pull it off.  You can set the interface when mpds
> are started and then
> the user pgms will use that same interface.  Or, you can let the
> mpds use one interface
> and then have your program use a different interface at runtime;
> this requires using
> the -machinefile option on mpiexec.
> I will assume for the present that you want to set the fast
> interface for the mpds and
> then have the pgm inherit that interface.  From your email, I
> assume you are also
> planning to start the mpds via mpdboot; that is actually the
> goofiest part.  Here's how
> it goes.
> Let's assume that some machines are named m1, m2, and m3.  Let's
> also assume that
> each host has a second name associated with a fast interface, e.g.
> m1-fast, m2-fast, and
> m3-fast.  Finally, we will assume that you are going to run mpdboot
> from m1 and that you
> want to use the fast interfaces.  Then you might create a hosts
> file named myhosts that
> contains:
>     m2-fast
>     m3-fast
> Since we are being picky about interfaces, I would leave m1/m1-fast
> out of the file and handle
> it via the cmd-line.  It can get very confusing for mpdboot to know
> which IP to associate with
> a given host.  Ultimately, it assumes that info about the local
> host is reliable from the cmd-line.
> So, you do this:
>     mpdboot -v -f myhosts -n 3 --ifhn=m1-fast
> That --ifhn arg is the tricky part.  It is the ifhn to be
> associated with the local host.  It will NOT be
> obtained from myhosts.  mpdboot will start one mpd on the local
> machine (m1 using the ifhn
> m1-fast) and then will start 2 others on m2-fast and m3-fast.  Now,
> mpich2 pgms should also
> use those interfaces.
> --ralph
> On WedMay 16, at Wed May 16 5:34PM, Jeff Squyres wrote:
>> Greetings.  I'm trying to run MVAPICH2 over ethernet to do some
>> performance comparisons, but I'm having a heck of a time trying to
>> figure out how to use a non-default TCP interface.
>> Specifically, eth0 is my "normal" gigE network (the IP address
>> associated with the hostname).  But I want to run an MVAPICH2 job
>> over ib0 -- my IPoIB interface.
>> I looked through the user documentation and didn't see anything
>> about how to do this -- did I miss it?  Pointers would be greatly
>> appreciated.
>> Thanks.
>> Jeff Squyres
>> Cisco Systems
Jeff Squyres
Cisco Systems
