[MPICH] Using non-default ethernet interfaces
    Ralph Butler
    rbutler at mtsu.edu
    Wed May 16 20:29:23 CDT 2007
This can be a bit tricky to get right no matter which way you try to
do it, and there are
multiple ways to pull it off.  You can set the interface when mpds
are started and then
the user pgms will use that same interface.  Or, you can let the mpds
use one interface
and then have your program use a different interface at runtime; this
requires using
the -machinefile option on mpiexec.
I will assume for the present that you want to set the fast interface
for the mpds and
then have the pgm inherit that interface.  From your email, I assume
you are also
planning to start the mpds via mpdboot; that is actually the goofiest
part.  Here's how
it goes.
Let's assume that some machines are named m1, m2, and m3.  Let's also
assume that
each host has a second name associated with a fast interface, e.g. m1-
fast, m2-fast, and
m3-fast.  Finally, we will assume that you are going to run mpdboot
from m1 and that you
want to use the fast interfaces.  Then you might create a hosts file
named myhosts that
contains:
     m2-fast
     m3-fast
Since we are being picky about interfaces, I would leave m1/m1-fast
out of the file and handle
it via the cmd-line.  It can get very confusing for mpdboot to know
which IP to associate with
a given host.  Ultimately, it assumes that info about the local host
is reliable from the cmd-line.
So, you do this:
     mpdboot -v -f myhosts -n 3 --ifhn=m1-fast
That --ifhn arg is the tricky part.  It is the ifhn to be associated
with the local host.  It will NOT be
obtained from myhosts.  mpdboot will start one mpd on the local
machine (m1 using the ifhn
m1-fast) and then will start 2 others on m2-fast and m3-fast.  Now,
mpich2 pgms should also
use those interfaces.
--ralph
On WedMay 16, at Wed May 16 5:34PM, Jeff Squyres wrote:
> Greetings.  I'm trying to run MVAPICH2 over ethernet to do some
> performance comparisons, but I'm having a heck of a time trying to
> figure out how to use a non-default TCP interface.
> Specifically, eth0 is my "normal" gigE network (the IP address
> associated with the hostname).  But I want to run an MVAPICH2 job
> over ib0 -- my IPoIB interface.
> I looked through the user documentation and didn't see anything
> about how to do this -- did I miss it?  Pointers would be greatly
> appreciated.
> Thanks.
> Jeff Squyres
> Cisco Systems
