[MPICH] MPI-IO, vector datatype
Rajeev Thakur thakur at mcs.anl.gov
Thu May 3 23:18:36 CDT 2007
Can you try writing to /tmp in case /home/rcarter is NFS.
Rajeev
> -----Original Message-----
> From: Russell L. Carter [mailto:rcarter at esturion.net]
> Sent: Thursday, May 03, 2007 9:03 PM
> To: Rob Ross
> Cc: Rajeev Thakur; mpich-discuss at mcs.anl.gov
> Subject: Re: [MPICH] MPI-IO, vector datatype
> Hi Rob,
> Rob Ross wrote:
> > Hi Russell,
> > The "nblocks(1)" sets that variable to 1, yes? Sorry, C++
> isn't my thing.
> Well, I mentioned that I tried multiple values for nblocks:
> 1, 2, and 4,
> for instance.  It would only increase the lines of code to add in
> a command line argument and I wanted to keep the code as small
> as possible, and it surely is.
> To get the wrong result, set nblocks to 2: nblocks(2).
> I'd like to emphasize that I have tried to change nothing about
> the algorithm in the read_all.c program featured on p. 65. of Using
> MPI-2.   Using that algorithm, I can't write a file and then
> read it with the same view.  My c++ code is written to make
> that especially clear.  The c++ code in mpicxx.h is just dead
> simple inline calls to the c api, so it's not a c++ problem.
> Maybe I'm wrong (cool, problem solved), and there's a working example
> somewhere?  That would be great.
> Best,
> Russell
> > A vector with a count of 1 is the same as a contig with a
> count equal to
> > the blocksize of the vector. This would explain what you're
> seeing. The
> > stride is only used if the count is greater than 1.
> > Regards,
> > Rob
> > Russell L. Carter wrote:
> >>> It is easy to run on a single machine. With MPD, all you
> need to do is
> >>> % mpd &
> >>> % mpiexec -n 2 a.out
> >> Works great.  No difference between pvfs2 and unix.
> >>> blocks of 4 ints each because you have defined INTS_PER_BLK=4.
> >> I'm guilty of a transcription error, crap.  Sorry about that,
> >> that's a stupid waste of time.  Should have been INTS_PER_BLK=8.
> >> With INTS_PER_BLK=4, I agree with your values but the problem
> >> is still there.  I have found what appears to be the problem.
> >> The stride arg in the Create_vector method appears to be
> >> ignored.  It doesn't matter what I set it to, 0 on up to
> >> nprocs*blocksize, the block data for each proc is written
> >> out contiguously.
> >> If I set the view displacement to be myrank*nints,
> >> the file always looks like this, without
> >> any holes, for any number of blocks and stride I set
> >> (nprocs is 2, neg is rank 0, pos is rank 1):
> >> 0000000           0          -1          -2          -3
> >> 0000020          -4          -5          -6          -7
> >> 0000040          -8          -9         -10         -11
> >> 0000060         -12         -13         -14         -15
> >> 0000100         -16         -17         -18         -19
> >> 0000120         -20         -21         -22         -23
> >> 0000140         -24         -25         -26         -27
> >> 0000160         -28         -29         -30         -31
> >> 0000200           0           1           2           3
> >> 0000220           4           5           6           7
> >> 0000240           8           9          10          11
> >> 0000260          12          13          14          15
> >> 0000300          16          17          18          19
> >> 0000320          20          21          22          23
> >> 0000340          24          25          26          27
> >> 0000360          28          29          30          31
> >> If I set the view displacements to
> >> blocksize*sizeof(int)*myrank, the file looks like this,
> >> for any stride (nblocks/proc is 2 here):
> >> 0000000           0          -1          -2          -3
> >> 0000020          -4          -5          -6          -7
> >> 0000100           0           1           2           3
> >> 0000120           4           5           6           7
> >> 0000140           8           9          10          11
> >> 0000160          12          13          14          15
> >> 0000200          16          17          18          19
> >> 0000220          20          21          22          23
> >> 0000240          24          25          26          27
> >> 0000260          28          29          30          31
> >> The further reduced code is appended.  As far as I can tell
> >> it should produce identical datatypes and views as the program
> >> on p. 65 of Using MPI-2.  It was my impression that that
> >> program was intended to read interleaved data, maybe it's
> >> not?
> >> Thanks,
> >> Russell
> >> #include "mpi.h"
> >> #include <iostream>
> >> using namespace std;
> >> struct tester
> >>     tester()
> >>         : myrank(MPI::COMM_WORLD.Get_rank()),
> >>           nprocs(MPI::COMM_WORLD.Get_size()),
> >>           bufsize(FILESIZE/nprocs), nints(bufsize/sizeof(int)),
> >>           nblocks(1), blocksize(nints/nblocks),
> >>           filetype(MPI::INT),
> >>           //fname("pvfs2:/mnt/pvfs/tst/testfile")
> >>           fname("/home/rcarter/mpibin/testfile")
> >>         std::ios::sync_with_stdio(false);
> >>         filetype.Create_vector(nblocks, blocksize, nprocs
> * blocksize);
> >>         filetype.Commit();
> >>         obuf = new int[bufsize];
> >>         ibuf = new int[bufsize];
> >>     ~tester() {
> >>         delete[] obuf;
> >>         delete[] ibuf;
> >>     void write()
> >>         for (int i = 0; i < nints; ++i) {
> >>             if (myrank)
> >>                 obuf[i] = i;
> >>             else
> >>                 obuf[i] = -i;
> >>         MPI::File f = open_set_view(MPI_MODE_CREATE |
> MPI_MODE_WRONLY);
> >>         f.Write_all(obuf, nints, MPI_INT, status);
> >>         f.Close();
> >>     void read()
> >>         MPI::File f = open_set_view(MPI_MODE_RDONLY);
> >>         f.Read_all(ibuf, nints, MPI_INT, status);
> >>         f.Close();
> >>             if (obuf[i] != ibuf[i]) {
> >>                 cerr << "myrank, i, obuf[i], ibuf[i]: " <<
> myrank << " "
> >>                      << i << " " << obuf[i] << " " <<
> ibuf[i] << endl;
> >> private:
> >>     static const int FILESIZE = 256;
> >>     int myrank, nprocs, bufsize, nints, nblocks,
> blocksize, *obuf, *ibuf;
> >>     MPI::Datatype filetype;
> >>     string fname;
> >>     MPI::Status status;
> >>     MPI::File open_set_view(int mode)
> >>         MPI::File f = MPI::File::Open(MPI::COMM_WORLD,
> fname.c_str(),
> >>                                       mode, MPI::INFO_NULL);
> >>         MPI::Offset disp = blocksize * sizeof(int) * myrank;
> >>         f.Set_view(disp, MPI_INT, filetype, "native",
> MPI_INFO_NULL);
> >>         return f;
> >> int main()
> >>     cerr << "Starting rwall.\n";
> >>     try {
> >>         MPI::Init();
> >>         tester t;
> >>         t.write();
> >>         MPI::COMM_WORLD.Barrier();
> >>         t.read();
> >>         MPI::Finalize();
> >>     } catch (exception &e) {
> >>         cerr << "\nCaught exception: " << e.what() << endl;
> >>         return -1;
> >>     } catch (MPI::Exception& e) {
> >>         cerr << "\nError:\n" << e.Get_error_string();
> >>         return -2;
> >>     cerr << "rwall end.\n";
> >>     return 0;
> Russell L. Carter
> Esturion, LLC
> 2285 Sandia Drive
> Prescott, Arizona 86301
> 928 308-4154
