[MPICH] MPI-IO, vector datatype
    Russell L. Carter
    rcarter at esturion.net
    Thu May  3 21:03:20 CDT 2007
Hi Rob,
Rob Ross wrote:
> Hi Russell,
> The "nblocks(1)" sets that variable to 1, yes? Sorry, C++ isn't my thing.
Well, I mentioned that I tried multiple values for nblocks: 1, 2, and 4,
for instance.  It would only increase the lines of code to add in
a command line argument and I wanted to keep the code as small
as possible, and it surely is.
To get the wrong result, set nblocks to 2: nblocks(2).
I'd like to emphasize that I have tried to change nothing about
the algorithm in the read_all.c program featured on p. 65. of Using
MPI-2.   Using that algorithm, I can't write a file and then
read it with the same view.  My c++ code is written to make
that especially clear.  The c++ code in mpicxx.h is just dead
simple inline calls to the c api, so it's not a c++ problem.
Maybe I'm wrong (cool, problem solved), and there's a working example
somewhere?  That would be great.
Best,
Russell
> A vector with a count of 1 is the same as a contig with a count equal to
> the blocksize of the vector. This would explain what you're seeing. The
> stride is only used if the count is greater than 1.
> Regards,
> Rob
> Russell L. Carter wrote:
>>> It is easy to run on a single machine. With MPD, all you need to do is
>>> % mpd &
>>> % mpiexec -n 2 a.out
>> Works great.  No difference between pvfs2 and unix.
>>> blocks of 4 ints each because you have defined INTS_PER_BLK=4.
>> I'm guilty of a transcription error, crap.  Sorry about that,
>> that's a stupid waste of time.  Should have been INTS_PER_BLK=8.
>> With INTS_PER_BLK=4, I agree with your values but the problem
>> is still there.  I have found what appears to be the problem.
>> The stride arg in the Create_vector method appears to be
>> ignored.  It doesn't matter what I set it to, 0 on up to
>> nprocs*blocksize, the block data for each proc is written
>> out contiguously.
>> If I set the view displacement to be myrank*nints,
>> the file always looks like this, without
>> any holes, for any number of blocks and stride I set
>> (nprocs is 2, neg is rank 0, pos is rank 1):
>> 0000000           0          -1          -2          -3
>> 0000020          -4          -5          -6          -7
>> 0000040          -8          -9         -10         -11
>> 0000060         -12         -13         -14         -15
>> 0000100         -16         -17         -18         -19
>> 0000120         -20         -21         -22         -23
>> 0000140         -24         -25         -26         -27
>> 0000160         -28         -29         -30         -31
>> 0000200           0           1           2           3
>> 0000220           4           5           6           7
>> 0000240           8           9          10          11
>> 0000260          12          13          14          15
>> 0000300          16          17          18          19
>> 0000320          20          21          22          23
>> 0000340          24          25          26          27
>> 0000360          28          29          30          31
>> If I set the view displacements to
>> blocksize*sizeof(int)*myrank, the file looks like this,
>> for any stride (nblocks/proc is 2 here):
>> 0000000           0          -1          -2          -3
>> 0000020          -4          -5          -6          -7
>> 0000100           0           1           2           3
>> 0000120           4           5           6           7
>> 0000140           8           9          10          11
>> 0000160          12          13          14          15
>> 0000200          16          17          18          19
>> 0000220          20          21          22          23
>> 0000240          24          25          26          27
>> 0000260          28          29          30          31
>> The further reduced code is appended.  As far as I can tell
>> it should produce identical datatypes and views as the program
>> on p. 65 of Using MPI-2.  It was my impression that that
>> program was intended to read interleaved data, maybe it's
>> not?
>> Thanks,
>> Russell
>> #include "mpi.h"
>> #include <iostream>
>> using namespace std;
>> struct tester
>>     tester()
>>         : myrank(MPI::COMM_WORLD.Get_rank()),
>>           nprocs(MPI::COMM_WORLD.Get_size()),
>>           bufsize(FILESIZE/nprocs), nints(bufsize/sizeof(int)),
>>           nblocks(1), blocksize(nints/nblocks),
>>           filetype(MPI::INT),
>>           //fname("pvfs2:/mnt/pvfs/tst/testfile")
>>           fname("/home/rcarter/mpibin/testfile")
>>         std::ios::sync_with_stdio(false);
>>         filetype.Create_vector(nblocks, blocksize, nprocs * blocksize);
>>         filetype.Commit();
>>         obuf = new int[bufsize];
>>         ibuf = new int[bufsize];
>>     ~tester() {
>>         delete[] obuf;
>>         delete[] ibuf;
>>     void write()
>>         for (int i = 0; i < nints; ++i) {
>>             if (myrank)
>>                 obuf[i] = i;
>>             else
>>                 obuf[i] = -i;
>>         MPI::File f = open_set_view(MPI_MODE_CREATE | MPI_MODE_WRONLY);
>>         f.Write_all(obuf, nints, MPI_INT, status);
>>         f.Close();
>>     void read()
>>         MPI::File f = open_set_view(MPI_MODE_RDONLY);
>>         f.Read_all(ibuf, nints, MPI_INT, status);
>>         f.Close();
>>             if (obuf[i] != ibuf[i]) {
>>                 cerr << "myrank, i, obuf[i], ibuf[i]: " << myrank << " "
>>                      << i << " " << obuf[i] << " " << ibuf[i] << endl;
>> private:
>>     static const int FILESIZE = 256;
>>     int myrank, nprocs, bufsize, nints, nblocks, blocksize, *obuf, *ibuf;
>>     MPI::Datatype filetype;
>>     string fname;
>>     MPI::Status status;
>>     MPI::File open_set_view(int mode)
>>         MPI::File f = MPI::File::Open(MPI::COMM_WORLD, fname.c_str(),
>>                                       mode, MPI::INFO_NULL);
>>         MPI::Offset disp = blocksize * sizeof(int) * myrank;
>>         f.Set_view(disp, MPI_INT, filetype, "native", MPI_INFO_NULL);
>>         return f;
>> int main()
>>     cerr << "Starting rwall.\n";
>>     try {
>>         MPI::Init();
>>         tester t;
>>         t.write();
>>         MPI::COMM_WORLD.Barrier();
>>         t.read();
>>         MPI::Finalize();
>>     } catch (exception &e) {
>>         cerr << "\nCaught exception: " << e.what() << endl;
>>         return -1;
>>     } catch (MPI::Exception& e) {
>>         cerr << "\nError:\n" << e.Get_error_string();
>>         return -2;
>>     cerr << "rwall end.\n";
>>     return 0;
Russell L. Carter
Esturion, LLC
2285 Sandia Drive
Prescott, Arizona 86301
928 308-4154
