[MPICH] mpich2-1.05 on the intel Mac OS X
Jiming Jin JimingJin at lbl.gov
Tue Mar 6 17:37:57 CST 2007
Hi Everyone,
  I just installed MPICH2-1.0.5p3 on my Pro Mac using the gfortran
compiler (Mac OS X with intel chips, 4 processors total).  I did
'make testing', and I get a message saying "No Errors".
I assume the installation was successful. I started mpd on this
computer, did several other tests and everything looked well.
I start to run my model (it is a climate model (WRF)) with 'mpiexec -
n 4 wrf.exe and I  only see one processor is running with more than
90% cpu, and other three processors are sleeping(with 0% cpu). When I
put the run to the background (Ctr-Z), I get the following error
pmpiexec_storm.lbl.gov: mpd_uncaught_except_tb handling:
   exceptions.IOError: [Errno 9] Bad file descriptor
     /usr/local/mpich/bin/mpiexec  1041  handle_stdin_input
         sys.stdin.flush()  # probably does nothing
     /usr/local/mpich/bin/mpdlib.py  743  handle_active_streams
         handler(stream,*args)
     /usr/local/mpich/bin/mpiexec  500  mpiexec
         rv = streamHandler.handle_active_streams(timeout=1.0)
     /usr/local/mpich/bin/mpiexec  1399  ?
         mpiexec()
Could someone give me suggestions on this problem? Thanks.
I compiled my model using the following options:
FC              =       mpif90 -f90=gfortran
LD              =       mpif90 -f90=gfortran
CC              =       mpicc -cc=/usr/local/gfortran/bin/gcc -
DMPI2_SUPPORT
SCC             =       /usr/local/gfortran/bin/gcc
SFC             =       gfortran
RWORDSIZE       =       $(NATIVE_RWORDSIZE)
# g95 does not like -r4. if you want promotion to -r8 add it to
PROMOTION below
#PROMOTION      =       -r$(RWORDSIZE) -i4
PROMOTION       =       -i4
CFLAGS          =       -DDM_PARALLEL \
                         -DMAXDOM_MAKE=$(MAX_DOMAINS) -DMAXPROC_MAKE=$
(MAX_PROC) -I../external/RSL_LITE
FCOPTIM         =       -O2 # -fast
FCDEBUG         =       #-g -O0
FCBASEOPTS      =       -fno-second-underscore -ffree-form  -fmax-
stack-var-size=99999768 $(FCDEBUG) # -Mlfs
FCFLAGS         =       $(FCOPTIM) $(FCBASEOPTS)
ARCHFLAGS       =       -DGRIB1  -DINTIO -DDM_PARALLEL \
                         -DIWORDSIZE=4 -DDWORDSIZE=8 -DRWORDSIZE=$
(RWORDSIZE) -DLWORDSIZE=4 -DNETCDF \
                         -DLIMIT_ARGS -DNMM_NEST=$(WRF_NMM_NEST) -DG95
CPP             =       /usr/local/gfortran/bin/cpp -C -P -traditional
