[MPICH] Replacing collective routines
Darius Buntinas buntinas at mcs.anl.gov
Wed Jul 18 10:18:52 CDT 2007
Hi Georg,
The communicator struct has a field called coll_fns which points to a
table of collective functions (MPID_Collops which is defined in
mpiimpl.h).  By default this field is NULL, so the default collective
functions are used.  In order to override one or more collective
functions for a communicator, create an instance of the MPID_Collops
table, and set the function pointers to your new functions.  Then in
each communicator for which you want to override the functions, set
coll->coll_fns to point to that table.  If any entry in MPID_Collops is
NULL, the default collective function will be used, so you need only
specify the functions you want to override.
In order to set the coll_fns function when the communicator is created,
define MPID_Dev_comm_create_hook() to set it (or define it to a function
which sets it).  There's also a MPID_Dev_comm_destroy_hook() if you need it.
If you're looking for an example, look in
src/mpid/ch3/channels/nemesis/src/ch3i_comm.c .  Here I override the
default barrier function.  I defined the comm create and destroy hooks
in src/mpid/ch3/channels/nemesis/include/mpidi_ch3_pre.h .
Does this make sense?
Darius
On 07/18/2007 01:54 AM, Georg Wassen wrote:
> Hello all,
> In the developer's section, a document about replacing collective
> routines is announced to come soon. Can somebody tell me the time frame?
> Or is this document already available in some sort of beta stage?
> Otherwise, can someone point me to the files, I should look at?
> Kind regards,
> Georg.
