[MPICH] test/mpi/comm/cmfree.c
Toon Knapen
toon.knapen at fft.be
Fri Jul 13 10:58:31 CDT 2007
Thanks. You guys outpaced me ;-)
t
Rajeev Thakur wrote:
> The current version of the test is attached.
> Rajeev
>> -----Original Message-----
>> From: Toon Knapen [mailto:toon.knapen at fft.be]
>> Sent: Friday, July 13, 2007 3:02 AM
>> To: Rajeev Thakur
>> Cc: mpich-discuss at mcs.anl.gov
>> Subject: Re: [MPICH] test/mpi/comm/cmfree.c
>>> Correction! The test is ok as it is. The comm_split is on
>> a different
>>> communicator.
>> The communicator I am talking about is a communicator that is created
>> directly after the MTest_Init as follows:
>> MPI_Comm_dup(MPI_COMM_WORLD,&comm);
>>> And a comm_free is called at the very end of the program if
>>> comm != null.
>> I do not see this (at least not in mpich2-1.0.5p4).
>> Additionally IMHO it
>> would not make since to test it to be different from comm_null before
>> comm_free'ing it because if this comm would be comm_null, the
>> test would
>> completely fail because this comm is used to determine the
>> rank of every
>> process etc which is used further down in the algorithm.
>> Actually, its a library of mine (that I link with the test) that
>> detected the communicator-leak. I first thought it was an error of my
>> library but finally I think that indeed there is a communicator-leak.
>> But of course, I might be overseeing something.
>> Thanks again in advance,
>> toon
